Author Topic: VE pump accelerator shaft O ring size  (Read 6764 times)
November 15, 2010, 03:11:20 am
regcheeseman
  • 714
« on: November 15, 2010, 03:11:20 am »
I've searched here, I've googled, I've downloaded manuals and part's suppliers catalogues, I've numerous part numbers....
Bosch 9 461 610 414
Zexen 146600-0100
DTP 40-1100
But all i want is the dimensions of the o-ring on the throttle shaft - I had a bag but the number on the bag doesn't help either.
Reply #1November 15, 2010, 08:22:23 am
Luckypabst
  • 502
Re: VE pump accelerator shaft O ring size
« Reply #1 on: November 15, 2010, 08:22:23 am »
6mm x 11mm
Durr... 6mm x 10mm
« Last Edit: November 16, 2011, 09:51:43 am by Luckypabst »
'82 TD Westy
'81 NA Caddy
Reply #2November 16, 2010, 03:46:54 pm
regcheeseman
  • 714
« Reply #2 on: November 16, 2010, 03:46:54 pm »
6mm x 11mm
Yep - I found that via google as well. not sure its right? That would mean a 2.5mm cross section.
Reply #3November 16, 2010, 06:35:50 pm
Luckypabst
  • 502
« Reply #3 on: November 16, 2010, 06:35:50 pm »
It's correct.
'82 TD Westy
'81 NA Caddy
Reply #4November 16, 2010, 07:22:13 pm
rabbitman
  • 2788
« Reply #4 on: November 16, 2010, 07:22:13 pm »
6mm x 11mm
Is that supposed to mean the inner measurement is 6mm and the outer 11mm? That sounds about right to me.
Reply #5November 16, 2010, 08:08:10 pm
Luckypabst
  • 502
« Reply #5 on: November 16, 2010, 08:08:10 pm »
Yes. The question came up before and that's the size of the O-ring in the Bosch kit.
'82 TD Westy
'81 NA Caddy
Reply #6November 18, 2010, 01:54:57 am
regcheeseman
  • 714
« Reply #6 on: November 18, 2010, 01:54:57 am »
Thank you very much  :)
Reply #7November 15, 2011, 06:02:42 am
regcheeseman
  • 714
« Reply #7 on: November 15, 2011, 06:02:42 am »
Ok - I bought a bag of 200 seals (minimum quantity)
They are WAY bigger than what comes out of the pump, the 6 mm bit is fine but the x-section (2.5mm) is massive.
Try and fit one and it's a huge battle, and normally they tear or nick on the way in and leak even worse.
So, has anyone actually got 6 x 11 x 2.5 orings that they are using successfully and if so, how do you get them in?
Just had a thought- I've not actually measured mine, maybe they are not what is written on the bag...
Reply #8November 15, 2011, 12:40:24 pm
mtrans
  • 308
« Reply #8 on: November 15, 2011, 12:40:24 pm »
I try hidraulic as well and no problemo.(in a harry)
I`ll improve my English
Reply #9November 15, 2011, 05:22:11 pm
Luckypabst
  • 502
« Reply #9 on: November 15, 2011, 05:22:11 pm »
My stuff is just a little too packed away to 3x check at the moment, maybe I'll dig it out tomorrow if I have a few minutes.
Did you also replace the bushing? I tried a new seal on an old bushing back when I was chasing leaks with no luck because the bushing takes a nasty egg-shaped wear pattern. And if you did replace the bushing, does it have a generous taper on the underside to accept the O-ring as you insert the shaft? (Bosch brand should be OK, but Chinese parts could be questionable).
Chris
For reference:
« Last Edit: November 15, 2011, 05:29:18 pm by Luckypabst »
'82 TD Westy
'81 NA Caddy
Reply #10November 16, 2011, 01:12:47 am
mtrans
  • 308
« Reply #10 on: November 16, 2011, 01:12:47 am »
In this part we don`t know there is made, Chinese can write any on box and because Bosch in Germany don`t made pumps I don`t belive they made O ring or seal.
Reply #11November 16, 2011, 04:14:39 am
regcheeseman
  • 714
« Reply #11 on: November 16, 2011, 04:14:39 am »
I've tried several different pumps all with original worn bushes.
It's not a case that they leak once fitted, more that they are so tight that the throttle shaft needs to be pressed in with a clamp, and once fitted is very stiff
I measured several used ones and they were all slightly over 6mm I/D with a sub 2mm cross section - typically 1.8 - 1.9 mm allowing for some deformation in use would be around the 2mm.
I've not noticed much lead in taper on any of the bushes, four on the bench last night - all the same.
Reply #12November 16, 2011, 08:14:05 am
92EcoDiesel Jetta
« Reply #12 on: November 16, 2011, 08:14:05 am »
New throttle bushings are available. Go to any Bosch fuel injection shop with your pump p/n and they can order you a new one. If you do that, please post the p/n of your pump, the bushing and how much you pay.
Reply #13November 16, 2011, 09:51:11 am
Luckypabst
  • 502
« Reply #13 on: November 16, 2011, 09:51:11 am »
Damn Damn Damn! (As Florida Evans would say).
I f'd up for sure. The bushing bore is 10mm. Being such an old thread, I'll not attempt to conjecture what I was thinking.
I went out and picked through the leftovers from a few Bosch kits and I have that O-ring, so to make things right, I'll happily send it off to you, if you can manage a week or so downtime. PM your address if interested.
Chris
'82 TD Westy
'81 NA Caddy
Reply #14November 16, 2011, 11:27:00 am
92EcoDiesel Jetta
« Reply #14 on: November 16, 2011, 11:27:00 am »
A Bosch fuel injection shop told me a new o-ring will not stop the leak if the bushing is worn.
