Author Topic: VE pump accelerator shaft O ring size  (Read 6754 times)
Reply #15November 16, 2011, 03:07:53 pm
regcheeseman
  • 714
Re: VE pump accelerator shaft O ring size
« Reply #15 on: November 16, 2011, 03:07:53 pm »
A Bosch fuel injection shop told me a new o-ring will not stop the leak if the bushing is worn.
Yep of course they would tell you that.  ::)
If a pump has a leak and a lot of slop in the bush - I'll replace the whole lot
But if I'm just gov-modding a pump (4 this week) I want to bung in a new seal regardless.
The post is not about the leaking - it's what size the o-ring is.
I went out and picked through the leftovers from a few Bosch kits and I have that O-ring, so to make things right, I'll happily send it off to you, if you can manage a week or so downtime.
Cheers for the offer - no downtime issue, Im building pumps for other people. If you could measure the ID and cross section I'd be very grateful.
Reply #16November 16, 2011, 04:23:57 pm
Luckypabst
  • 502
« Reply #16 on: November 16, 2011, 04:23:57 pm »
Should be 6mm ID & 2mm cross-section.  :-[
'82 TD Westy
'81 NA Caddy
Reply #17November 17, 2011, 08:44:14 am
regcheeseman
  • 714
« Reply #17 on: November 17, 2011, 08:44:14 am »
Now, that makes a lot more sense. Thanks.  :)
