Author Topic: Leaky injector  (Read 4527 times)
June 14, 2009, 03:39:30 pm
LoneWolf
Leaky injector
« on: June 14, 2009, 03:39:30 pm »
Hi all,
         just got home after driving for nearly 200miles without any issues, parked up for a couple of hours, started her up again and there was a definate misfire, i figured it was a bad plug, so i keep driving.
  When i get home its still missing, so i pop the bonnet and see theres fuel pissing from the top of my no.2 injector, where the solid line bolts onto the injector.
 Is it worth trying to tightn the nut a bit more, or would it be better to take the injector out?
 Also, what could have caused this to suddenly happen, blocked/ damaged nozzle perhaps?
 Any help would be muchos appreciated
 Matt
Reply #1June 15, 2009, 01:02:30 am
dave friday
  • 122
Re: Leaky injector
« Reply #1 on: June 15, 2009, 01:02:30 am »
yes, tighten it up [ i had the no4 leak ,tightened it up no leak!! ]
good luck.
1992 1600 td syncro camper
Reply #2June 15, 2009, 02:52:25 am
Patrick
  • 1034
Re: Leaky injector
« Reply #2 on: June 15, 2009, 02:52:25 am »
Tightening it up might work, but they also crack lines from vibration. You may need a new injector line.
Reply #3June 15, 2009, 12:37:12 pm
Re: Leaky injector
« Reply #3 on: June 15, 2009, 12:37:12 pm »
do you have the injector line holder installed? don't tighten the injector line too tight... i'd say back it off and then re-tighten.
Reply #4June 17, 2009, 12:00:07 am
LoneWolf
Re: Leaky injector
« Reply #4 on: June 17, 2009, 12:00:07 am »
i tightened it up and went for a drive, after a few mins there was an Uber strong smell of fuel, looked under the bonnet and guess what, i had 1 clean snapped fuel line.
 thanks for the advive guys :)
Reply #5June 17, 2009, 10:25:49 am
Doug
Re: Leaky injector
« Reply #5 on: June 17, 2009, 10:25:49 am »
Remember to install those little clamps over your steel lines as they are important in damping out the harmonic vibration that can cause the injector lines to fracture. I had a line break on my Landcruiser that was missing the clamps. They are easy to make up with some flat steel and rubber belting if you don't care to buy them.
Reply #6June 17, 2009, 10:56:28 am
cyrus #1
  • 360
Re: Leaky injector
« Reply #6 on: June 17, 2009, 10:56:28 am »
Also make sure to loosen all the injector line nuts at the back side of the injection pump when re-timing.  It doesn't take much in the way of preload to crack metal when subjected to vibration.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
