Author Topic: whahahaha (Meniacle laughing) I hope this works out  (Read 40371 times)
Reply #60November 15, 2007, 08:42:11 am
addautomotive
« Reply #60 on: November 15, 2007, 08:42:11 am »
Sorry, got his name wrong, it is Klaus
He had the car on ebay at one point:
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=180123547214&ssPageName=ADME:L:LCA:CA:31
He got rear-ended back in nov 06
Reply #61November 15, 2007, 11:18:00 am
Slave2School
  • 531
« Reply #61 on: November 15, 2007, 11:18:00 am »
Hmm I couldn't check the link at work, but that isn't my car.  That is a 524td and mine is actually the 3 series E30 Chassis with the same engine in it as that car would have had.  Mine is also a 5spd :)
2002 ford focme wagon
Reply #62November 15, 2007, 12:24:44 pm
addautomotive
« Reply #62 on: November 15, 2007, 12:24:44 pm »
weird,
How many red bimmer diesels running on SVO could there be in NS?
Reply #63November 15, 2007, 12:26:14 pm
Slave2School
  • 531
« Reply #63 on: November 15, 2007, 12:26:14 pm »
I guess a few lol!  It seems they like to be rear ended too!  Bastards not paying attention taking out these museum pieces....It hink I may fit extra bright tail lights and a 3rd brake light as mine does not have that feature.
Reply #64November 15, 2007, 07:22:52 pm
jackbombay
  • 599
« Reply #64 on: November 15, 2007, 07:22:52 pm »
Quote from: "Slave2School"
   So how does one go about fitting that piece back in off a non wrecked car? Looks like there is a small gap all the way around the new black piece and he'll use small pieces welded to both to bridge the gap and hold it all together? Will he use a
Flange tool on both edges so the patch will be flush with everything else? What about around corners? [/body work noob]
Reply #65November 15, 2007, 07:44:05 pm
Slave2School
  • 531
« Reply #65 on: November 15, 2007, 07:44:05 pm »
That is just resting on blocks not 100% trimmed in that picture so it looks alot worse than it is now.
He noted there are only a few spots with gaps and the rest will line up  there won't be any need for much else other than welding and grinding afterword.  I'm not much of a metal worker so I can't get into the specifics since that is his forte.
just talking with him on msn, he says he's going to butt weld it then add additional metal where there is anything strutural to reinforce that area (he already has one of those tools).  Yes Chris is into serious hours on this car, I will owe him my 3rd born :)
Reply #66November 16, 2007, 10:01:56 am
jackbombay
  • 599
« Reply #66 on: November 16, 2007, 10:01:56 am »
  Ahhh, cool, didn't realize it wasn't trimmed all the way yet. The fact that its an outside corner makes it a lot easier to get it to fit right, I have an awkward inside corner/floorboard/footwell to patch in my vanagon, not totally sure how I'm going to do it yet, very accurate measurements seems like the best way to go so far.
Reply #67November 16, 2007, 11:35:24 am
Slave2School
  • 531
« Reply #67 on: November 16, 2007, 11:35:24 am »
Yes Chris spent maybe 3 days measuring :)  after each little trim he measures again so it is a slow process indeed.
Reply #68November 20, 2007, 01:20:31 pm
nkb
  • 154
« Reply #68 on: November 20, 2007, 01:20:31 pm »
Quote from: "addautomotive"
this car was at my previous place of employment since late 05 so it couldn't be same car. different vin too
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #69November 23, 2007, 08:58:54 am
giulianot
  • 146
« Reply #69 on: November 23, 2007, 08:58:54 am »
Excellent progress !!  :D  this is a really cool project 8)  does it have a lsd in the rear? my 1990 325is has one just wondering if the diesels have it to
 :wink:
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #70November 23, 2007, 01:08:28 pm
Slave2School
  • 531
« Reply #70 on: November 23, 2007, 01:08:28 pm »
It does now :D  I bought one on ebay from California, it has the nice solid rubber bushing already installed too.  2.93 rear same as the stock one actaully, just LS.
In other news, I appear to be going away for a few months, so I will be able to help Chris even less than I have been already :(  I will likely be leaving early Jan to come back mid May, if my away period works I'll be moving to the Trenton, ON area.
Reply #71November 24, 2007, 05:47:05 pm
Slave2School
  • 531
« Reply #71 on: November 24, 2007, 05:47:05 pm »
Crank scraper on the way Mwhahahahaha
Reply #72November 24, 2007, 06:31:28 pm
jackbombay
  • 599
« Reply #72 on: November 24, 2007, 06:31:28 pm »
From where? I can't imagine that it would be worthwhile to make those aftermarket.
Reply #73November 24, 2007, 06:34:48 pm
Slave2School
  • 531
« Reply #73 on: November 24, 2007, 06:34:48 pm »
http://www.crank-scrapers.com/bmw.html
The ETA 2.7L engine has the same strok as m21 and the owner/manufacture said according to his books his scraper will fit my bottom end.  Seems like a great fellow to deal with and if there are issues it is just a small piece of steel that can be filed as needed.
Actually the turbo builders will use a m21 crank or the 2.7L crank in the "stroker on a budget" builds.
Reply #74March 01, 2008, 07:26:06 am
jackbombay
  • 599
« Reply #74 on: March 01, 2008, 07:26:06 am »
Progress?
