Author Topic: rough idle  (Read 6700 times)
October 18, 2006, 06:00:46 pm
rough idle
« on: October 18, 2006, 06:00:46 pm »
any reasons for a rough idle on a 1.6 td? my car is at 1000-1100 idle and it seems rough, and i know before it seemed fine and i had at liek 700 and i couldn't even feel it, it's not missing or anything and it runs strong... could be injectors or maybe bent valves or something?
Reply #1October 18, 2006, 06:25:15 pm
sethyboy85
  • 284
rough idle
« Reply #1 on: October 18, 2006, 06:25:15 pm »
It's been cool out here lately, glowplug out?
rough warm or rough cold?
What kind of fuel have you been running?
How much boost were your running last night?  :wink:
Pull an injector and see if the seal is carboned up (bad spray pattern will result rough idle but smooth driving)
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #2October 18, 2006, 07:02:07 pm
rough idle
« Reply #2 on: October 18, 2006, 07:02:07 pm »
are all your motor mounts good?
Reply #3October 19, 2006, 07:44:59 pm
rough idle
« Reply #3 on: October 19, 2006, 07:44:59 pm »
i know both trans and the front mount are all good, and the passenger side should be decent as i remember when we did the motor swap, it does it warm and cold, but it's a relatively new thing.  so i wouldn't want to think it's the injectors...
Reply #4October 19, 2006, 07:49:19 pm
rough idle
« Reply #4 on: October 19, 2006, 07:49:19 pm »
Run a compression check and see if you have a shot cylinder
Reply #5October 20, 2006, 10:09:30 am
1slowvw
rough idle
« Reply #5 on: October 20, 2006, 10:09:30 am »
My engine had a really rough idle after i overheated the thing, turns out i had warped the head and scored a piston. The thing ran but it was rough.
            1SlowVW
Reply #6October 21, 2006, 09:36:04 pm
rough idle
« Reply #6 on: October 21, 2006, 09:36:04 pm »
mine went downhill from an overheat too... stupid fan died on me... one reason I hate a/c models...
Reply #7October 23, 2006, 07:32:22 am
Powjetta
  • 152
    San Diego CA
rough idle
« Reply #7 on: October 23, 2006, 07:32:22 am »
I replaced the front mount and the passenger side mount on mine and it really made a difference.  I couldn't tell til I had them out side by side how much tighter the new mount was.  If it's just at idle and not when the rpm's are up then I would replace mounts.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #8October 25, 2006, 06:07:59 pm
rough idle
« Reply #8 on: October 25, 2006, 06:07:59 pm »
it could be the motor but this thing runs strong and pulls like a mule, puts a hurting on alot of cars in town haha
Reply #9October 26, 2006, 08:16:43 am
rough idle
« Reply #9 on: October 26, 2006, 08:16:43 am »
right before I had my engine fixed from the overheat, it would shake/vibrate pretty bad.  it just kept getting worse too :(
Reply #10October 26, 2006, 05:20:54 pm
rough idle
« Reply #10 on: October 26, 2006, 05:20:54 pm »
i will add that my older '86 jetta td vibrated pretty bad.  we're talking some mad dash vibrations.  i thought for sure it would vibrate itself to death  :lol:  but other than hard cold starting, it just kept purring along!  it went to its grave before i could kill it myself though :(  turbo in that thing was weird too... kicked in at 100km/h and brought me up to 110km/h hehe try explaining that to the officer...  and i attribute all of that to bad compression.  hopefully your motor doesn't have bad compression
