General Information
Troubleshooting
rough idle
Topic: rough idle (Read 6702 times)
October 18, 2006, 06:00:46 pm
rough idle
October 18, 2006, 06:00:46 pm »
any reasons for a rough idle on a 1.6 td? my car is at 1000-1100 idle and it seems rough, and i know before it seemed fine and i had at liek 700 and i couldn't even feel it, it's not missing or anything and it runs strong... could be injectors or maybe bent valves or something?
October 18, 2006, 06:25:15 pm
sethyboy85
rough idle
October 18, 2006, 06:25:15 pm »
It's been cool out here lately, glowplug out?
rough warm or rough cold?
What kind of fuel have you been running?
How much boost were your running last night? :wink:
Pull an injector and see if the seal is carboned up (bad spray pattern will result rough idle but smooth driving)
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
October 18, 2006, 07:02:07 pm
rough idle
October 18, 2006, 07:02:07 pm »
are all your motor mounts good?
October 19, 2006, 07:44:59 pm
rough idle
October 19, 2006, 07:44:59 pm »
i know both trans and the front mount are all good, and the passenger side should be decent as i remember when we did the motor swap, it does it warm and cold, but it's a relatively new thing. so i wouldn't want to think it's the injectors...
October 19, 2006, 07:49:19 pm
rough idle
October 19, 2006, 07:49:19 pm »
Run a compression check and see if you have a shot cylinder
October 20, 2006, 10:09:30 am
1slowvw
rough idle
October 20, 2006, 10:09:30 am »
My engine had a really rough idle after i overheated the thing, turns out i had warped the head and scored a piston. The thing ran but it was rough.
1SlowVW
October 21, 2006, 09:36:04 pm
rough idle
October 21, 2006, 09:36:04 pm »
mine went downhill from an overheat too... stupid fan died on me... one reason I hate a/c models...
October 23, 2006, 07:32:22 am
Powjetta
San Diego CA
rough idle
October 23, 2006, 07:32:22 am »
I replaced the front mount and the passenger side mount on mine and it really made a difference. I couldn't tell til I had them out side by side how much tighter the new mount was. If it's just at idle and not when the rpm's are up then I would replace mounts.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
October 25, 2006, 06:07:59 pm
rough idle
October 25, 2006, 06:07:59 pm »
it could be the motor but this thing runs strong and pulls like a mule, puts a hurting on alot of cars in town haha
October 26, 2006, 08:16:43 am
rough idle
October 26, 2006, 08:16:43 am »
right before I had my engine fixed from the overheat, it would shake/vibrate pretty bad. it just kept getting worse too
October 26, 2006, 05:20:54 pm
rough idle
October 26, 2006, 05:20:54 pm »
i will add that my older '86 jetta td vibrated pretty bad. we're talking some mad dash vibrations. i thought for sure it would vibrate itself to death :lol: but other than hard cold starting, it just kept purring along! it went to its grave before i could kill it myself though
turbo in that thing was weird too... kicked in at 100km/h and brought me up to 110km/h hehe try explaining that to the officer... and i attribute all of that to bad compression. hopefully your motor doesn't have bad compression
General Information
Troubleshooting
rough idle
