Author Topic: Not great numbers, but some good information.  (Read 5380 times)
September 05, 2006, 10:59:55 am
DVST8R
  • 535
« on: September 05, 2006, 10:59:55 am »
We had our end of the season at the local drag strip yesterday, and as such it was free runs. So I couldn't pass that up and made a couple of pass's.
Track info:
-2400' ASL
-Air Temp 30C / 86F
-Humidty 42%
Car info:
2910lbs race weight, same as street weight not prepped at all (3/4 tank fuel, full interior, with stereo ect...)
1.6TD ~ 40K on rebulit motor
Stock DP, 2.25" exhaust toilet bowl back
Stock IP (no turns on the fuel screw, no gov mod)
Custom Cut fuel pin (looks like Hillfolker's)
Unpluged wastegate (max psi I saw in the run ~ 25psi, thats all the fuel I had)
First run, clutch started sliping in second and never totally recovered, also completely asleep at the lights (my excuse I was trying to build boost at the line, and looked at my boost gauge and missed the first light).
-rec .935
-I1 2.685
-I2 7.757
-I3 12.294
-I4 16.259
-E.T. 19.578
-MPH 67.995
Next run clutch slipped so bad, I wasn't sure I would be able to drive home, I could rev it like it was in neutral or half engaged. Thankfully after some cool down time it came back close to how it was.
So with the clutch slipping those numbers still calculate out to like ~80whp or like a 12hp gain over stock with just a fuel pin! Cost of mods involved $0, total time like 15min with: opening the top, bench grinder, puting it back together, and cutting the wastegate line and pluging the other end.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #1September 05, 2006, 12:11:03 pm
DVST8R
  • 535
« Reply #1 on: September 05, 2006, 12:11:03 pm »
Also take note, because of the slipping clutch there is like a 4MPH differnce vs E.T
Here are a couple somewhat recent pics of my car:
Reply #2September 05, 2006, 02:46:20 pm
Justin
  • 455
« Reply #2 on: September 05, 2006, 02:46:20 pm »
same here not impressive but good info
of my thesis testing at Kettering University last week, the engine is a 1.5 liter Turbo diesel, I am running about 12 pounds of boost, power was at the wheels strapped down pretty tight, the dyno is a mustang ATV chassis dyno, I am told that they are notorious for low numbers but its only hear say so I am in no way saying that my car is more powerfull than this.
I am making no smoke, and have the fuel turned back with an NA pump, check out car domain and look at the 1984 rabbit, look at the cracked block and tell me what you think, it cracked through the 2nd main bearing in from the trans side. I was running 27psi if any of you were wondering but I dont think that killed the block.
I tested 6 different fuels, diesel, B5, B20, B50, B100, and heated Veg oil
http://www.cardomain.com/ride/2223781
later
Justin
www.archeryprostaffmi.com
Reply #3September 05, 2006, 04:18:14 pm
« Reply #3 on: September 05, 2006, 04:18:14 pm »
i dunno, make it smoke  :twisted: then dyno it
Reply #4September 05, 2006, 04:26:04 pm
Justin
  • 455
« Reply #4 on: September 05, 2006, 04:26:04 pm »
the problem with that is that I have a 1.5 in it, I dont want to blow this block up by cracking the block by the weak shallow headbolts since I am really relying on this until I get the TDI caddy going then the turbo setup is coming off and going on the TDI until I can build up a Twin setup. when the turbo comes off the 4 door then I will put it back to NA and fix the body and sell it with the rebuilt 1.5 liter. so for right now 53 hp best run is good enough for me sorry I havent tried more mods for power, I would have but I cracked the 1.6
Reply #5September 05, 2006, 04:43:47 pm
  • 1156
    • Malone Tuning Ltd.
« Reply #5 on: September 05, 2006, 04:43:47 pm »
Good baseline numbers.. 2910lbs is mighty heavy.  :shock:
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #6September 05, 2006, 07:18:36 pm
SMOKEYDUB
  • 630
« Reply #6 on: September 05, 2006, 07:18:36 pm »
mine with me in it 3/4 tank of fuel ( me being 150 lbs)  2515 lbs
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #7September 05, 2006, 08:04:41 pm
DVST8R
  • 535
« Reply #7 on: September 05, 2006, 08:04:41 pm »
Me (190lbs), Stereo, 2-amps, sub and box spare tire and jack ect.., Recaro interior (this is the real weight, but I love it and wouldn't trade it for anything. Heavy wheels... Dunno its just kinda a fat pig, but I enjoy it.
Oh and it doesn't smoke unless its lugged.  :D
Reply #8September 06, 2006, 12:05:17 am
935racer
Re: Not great numbers, but some good information.
« Reply #8 on: September 06, 2006, 12:05:17 am »
Quote from: DVST8R
Good thing you know someone with some mad pin cutting skillz yo :roll:  :lol:
Reply #9September 07, 2006, 08:32:54 am
RAMMSTEIN
  • 331
« Reply #9 on: September 07, 2006, 08:32:54 am »
2910 lb is way too much for an A2.
My A2 weighs 1090 kg (2400 lb) with some stuff in the trunk and 1190 kg (2625 lb) with me.
A friend of mine has a Trophy (every option in the book, no ABS, but G60 front brakes) and his car weighs 1100kg (2425 lb) on the dot.
Are you driving around with a cement block in the trunk? :lol:  :?:
Rammstein
In abscence of light, darkness prevails.
Reply #10September 07, 2006, 07:52:42 pm
DVST8R
  • 535
« Reply #10 on: September 07, 2006, 07:52:42 pm »
Well I got the big brake's too... :lol: I hoenstly don't know why it ways that much, but I weighed it again today on another scale, @ a local mill (and it weighed me within 3lbs) and I got 2870lbs with like an 1/8th of a tank so...?
Reply #11September 08, 2006, 02:41:08 pm
RAMMSTEIN
  • 331
« Reply #11 on: September 08, 2006, 02:41:08 pm »
Maybe you weigh 500 lb, who knows...
Rammstein
