Author Topic: aaz turbo option  (Read 55186 times)
Reply #165June 22, 2015, 12:57:43 pm
Alcaid
  • 549
Re: aaz turbo option
« Reply #165 on: June 22, 2015, 12:57:43 pm »
You can smoke even with an 8mm pump with too long duration. If only Giles would tell how much cc his pumps gives as that would give a quantitative number of how super those pumps are or not. 120cc 11mm pump dynoed 204-205whp
'10 VW Passat 1.6TDI Highline
Reply #166June 22, 2015, 04:08:02 pm
« Reply #166 on: June 22, 2015, 04:08:02 pm »
2.5" intercooler piping is a bit big. 2" will help with smoke, as the 2.5" would be a race or all high rpm only application. That may help with the smoke early. Especially if you have a bigger than needed IC.
I say something is off as I have a Giles 10mm maxed out and now that I eliminated the boost leak I have 0 smoke and EGT around 700f peak...I did a lot of porting and head work though. I don't think it would make that much difference.
Reply #167June 22, 2015, 08:50:24 pm
« Reply #167 on: June 22, 2015, 08:50:24 pm »
Like Alcaid says... The challenge isn't so much total fuel quantity as it is timing. If you're running a 10mm pump and smaller injectors you can make lots of smoke and high EGTs without making all that much power. It's about getting it in there fast enough that it gets burned while the piston is in the right place.
Reply #168June 22, 2015, 11:14:42 pm
« Reply #168 on: June 22, 2015, 11:14:42 pm »
smaller injectors in an IDI?
On my setup it has an aaz camplate with the 10mm head.
Reply #169June 22, 2015, 11:22:44 pm
« Reply #169 on: June 22, 2015, 11:22:44 pm »
Ah crap. Wasn't paying attention to which forum I was in. A 10mm pump would actually be pretty hot on an IDI.
Reply #170July 03, 2015, 11:24:47 am
mark3kid
  • 80
« Reply #170 on: July 03, 2015, 11:24:47 am »
Not sure guys I still have yet to get it dynoed but its still working pretty decent I am overall very very happy with the performance of the car and setup it drives great I just need to figure my egts out which I am continuously getting lower
Sent from my Nexus 5 using Tapatalk
When that turbo hits full boost you will forget all about the work to get you there, I promise It's pretty similar to women giving birth... - Alcaid
Reply #171July 03, 2015, 03:42:33 pm
mark3kid
  • 80
« Reply #171 on: July 03, 2015, 03:42:33 pm »
Doesn't matter now guys the engine blew up
Reply #172July 03, 2015, 07:28:45 pm
RunninWild
  • 609
« Reply #172 on: July 03, 2015, 07:28:45 pm »
WHAT!! Howd that happen? Any plans for that holset ;)?
Reply #173July 04, 2015, 02:24:19 am
golfmk1tdr
  • 53
    • My car's forum thread
« Reply #173 on: July 04, 2015, 02:24:19 am »
Are you giving up? In my coutry 1.6 D engines are so cheap I don't really care if my blows up.
As long the turbo survives...
Please report what happened.
1.6+holset MK1 Golf TDR /TurboDieselRacing
(no GTD because GT is grand tourismo and there is nothing grand and touristic in my stripped out lowered beast)
Reply #174July 04, 2015, 06:58:15 pm
Toby
  • 728
« Reply #174 on: July 04, 2015, 06:58:15 pm »
I'd be very interested to see what your exhaust manifold pressure is like at 40 PSI though, you're in the danger zone for the exhaust valves not closing.
Says who? What do you think is going to hold the valves open? 40psi on the intake side? Not likely.
Reply #175July 04, 2015, 07:01:24 pm
« Reply #175 on: July 04, 2015, 07:01:24 pm »
40 on the intake side could easily be 60+ exhaust manifold pressure...
Reply #176July 05, 2015, 07:49:58 pm
mark3kid
  • 80
« Reply #176 on: July 05, 2015, 07:49:58 pm »
I disintegrated a rod bearing completely destroyed it to nothing but  pieces of metal in my oil pan. Bottom end is toast. And I can't afford another rebuild after 1250kms
Reply #177July 06, 2015, 06:21:27 am
Gizmoman
  • 1301
« Reply #177 on: July 06, 2015, 06:21:27 am »
Very sorry for your loss. Do you know what caused the issue?
Reply #178July 07, 2015, 05:58:51 am
mark3kid
  • 80
« Reply #178 on: July 07, 2015, 05:58:51 am »
To much boost I'd say and the bottom end just couldn't handle it. Very sad but nothing I can do now
Reply #179September 15, 2015, 06:31:03 pm
mark3kid
  • 80
« Reply #179 on: September 15, 2015, 06:31:03 pm »
Hey guys just wanted to put a little update about this. I put an engine in it. Did a little stuff and now I make just about 50psi yes that's right 50psi!!! Hauls pretty good. Egts get high but I just hold it and it keeps pulling
