Author Topic: AAZ project update  (Read 34077 times)
Reply #15June 23, 2013, 09:00:04 am
Gizmoman
  • 1301
Re: AAZ project update
« Reply #15 on: June 23, 2013, 09:00:04 am »
The bell housing and starter tip may still need a little clearancing for the pressure plate.
Hmm, OK.
Could that be the reason it wont stab in?
I used an alignment tool for the clutch plate when I torqued down the pressure plate - should slide right in. I also blocked one wheel and rotated the other - no luck.
Reply #16June 23, 2013, 09:11:50 am
« Reply #16 on: June 23, 2013, 09:11:50 am »
No, that's not the reason.  Probably the reason it won't go in easily is because of the clutch slave/throw out bearing.  Put a c-clamp on the clutch release lever to hold it all the way UP and it will slide in easily.
Reply #17June 23, 2013, 09:18:42 am
Gizmoman
  • 1301
« Reply #17 on: June 23, 2013, 09:18:42 am »
OK - I'll do that.
Reply #18June 23, 2013, 09:40:07 am
Gizmoman
  • 1301
« Reply #18 on: June 23, 2013, 09:40:07 am »
Worked great and went in about 1/2" and stopped.
Do I remove the clamp now? It would seem that I am pushing the throwout bearing against the pressure plate at this point.
Reply #19June 23, 2013, 09:54:43 am
Gizmoman
  • 1301
« Reply #19 on: June 23, 2013, 09:54:43 am »
That did it - took off the clamp (I used bailing wire instead) and it went in pretty easily with a clamp on the bottom and one of the bolts. I didn't force it at all.
Libby, will I have to get it running before I find out about the clearancing you mentioned?
Also, it seems odd that the Gee-Bee hose ends to the radiator pipes are so much larger that the new SS ones I just installed (same diameter as stock). Also, the connector on the back (end) of the head is much larger than the 5/8 heater hose. Isn't that what it goes to?
Reply #20June 23, 2013, 01:00:25 pm
« Reply #20 on: June 23, 2013, 01:00:25 pm »
I would recommend installing the engine to trans bolts and starter.  Then rotate it by hand a few times.  If you don't feel anything, then bump the starter a couple times.  Then pull it apart and see if there is any clearancing necessary.
Reply #21June 23, 2013, 01:35:31 pm
Gizmoman
  • 1301
« Reply #21 on: June 23, 2013, 01:35:31 pm »
Will do - thanks. Already have most of the bolts in and the carrier bars as well. I'm hoping that there's no issues but I guess I'll find out. If you had to clearance, I will most likely as well. I should have read your post first.
I'm done with this for the weekend - havta move some furniture for the in-laws.
Reply #22July 04, 2013, 09:05:40 am
Gizmoman
  • 1301
« Reply #22 on: July 04, 2013, 09:05:40 am »
OK,
Engine back out and sure enough, there's two very small areas of interference (as you said there may be).
One is on the bottom of the timing arrow and the other is on a bump next to the timing hole - again, just as you posted.
I hope hitting those with a grinder takes care of it. It seems odd that my fully charged dual batteries wouldn't turn it over more than one rev.
Reply #23July 04, 2013, 09:18:17 am
« Reply #23 on: July 04, 2013, 09:18:17 am »
thats why you supposed to turn by hand.. :P i watched guy pull engine 3x and pan.. cause he screwed up main shaft length then thinking bottom end locked.. back in 96...
Reply #24July 04, 2013, 09:30:12 am
Gizmoman
  • 1301
« Reply #24 on: July 04, 2013, 09:30:12 am »
I did turn it by "hand" - well a 2 foot breaker bar. It seemed a bit stiffer that what it was on the stand but I just figured it was additional drag from being hooked up to the tranny.
I also didn't modify my main shaft length - it's still stock. Am I supposed to? It seemed to slide in fine after I fiddled with the clutch lever.
Reply #25July 04, 2013, 09:52:40 am
« Reply #25 on: July 04, 2013, 09:52:40 am »
no no listen to me on main shaft length.. libby should know that one.. when people put diesel bell housings on the non diesel tranny the main shaft has to be shortened...
your  issue is 02a flywheel crap..
he figured out his mistake when he learned loosing up all bolts to tranny 1/2 turn allowed stuff to turn again...
but libby said turn by hand as you tighten it up.. so thats why.. he learned long ago on that silly stuff..
the engine really should roll over nice by hand.. if you need a cheater pipe.. id rethink your work... cam cap, main cap is on backwards.. something.. any engine ive rebuilt i can turn by alt with wrench/socket where v belt no slip...
Reply #26July 04, 2013, 12:00:56 pm
Gizmoman
  • 1301
« Reply #26 on: July 04, 2013, 12:00:56 pm »
I am listening - libby said nothing of the shaft shortening - just clearancing of the bell housing and the nose of the starter
Reply #27July 04, 2013, 12:03:32 pm
« Reply #27 on: July 04, 2013, 12:03:32 pm »
no no as in no do not... ignore mainshaft... unless you built custom tranny too..
Reply #28July 04, 2013, 12:13:20 pm
Gizmoman
  • 1301
« Reply #28 on: July 04, 2013, 12:13:20 pm »
Got it.
I clearanced the bellhousing and the starter nose where it seems to be touching. Man I hope this is all the clearancing i need. I tried to find libbys post and photos - no luck.
Stabbing this in is a bit of a chore with my home made setup.
Edit - I found the link http://www.thesamba.com/vw/forum/viewtopic.php?t=549444
« Last Edit: July 04, 2013, 12:20:30 pm by Gizmoman »
Reply #29July 04, 2013, 12:32:00 pm
« Reply #29 on: July 04, 2013, 12:32:00 pm »
Your trans was already set up for the AAZ engine so you shouldn't have to mess with the input shaft.  The gasser transaxles have an input shaft that is approx 11mm longer and so if fitting a diesel bell housing to gasser trans you need to call a rabbi.
