General Information
General
still to cold for motor oil...
Pages:
Topic: still to cold for motor oil... (Read 11825 times)
Reply #15
February 03, 2013, 07:39:04 pm
Re: still to cold for motor oil...
Reply #15 on:
February 03, 2013, 07:39:04 pm »
I was thinking change the filter and get it running and then go add some gasoline to the mix. hah
Yes 4 yrs. It has not shown an issue at all until now
. I had a replacement, but I used it on the woman's 88 when we revived it back in October.
Reply #16
February 03, 2013, 07:52:24 pm
Reply #16 on:
February 03, 2013, 07:52:24 pm »
sadly I have heard that song or lack of song before. My kids think it is funny as we have several thrift stores in our area.
Round 2
Reply #17
February 03, 2013, 08:29:36 pm
Reply #17 on:
February 03, 2013, 08:29:36 pm »
You take that back right now. That song is totally awesome. I wear your grandpas clothes, i look incredabowl!
Reply #18
February 03, 2013, 08:33:06 pm
Moderator
4549
Reply #18 on:
February 03, 2013, 08:33:06 pm »
Incredabowl maybe F--ing awesome? NOT!
Reply #19
February 03, 2013, 08:41:49 pm
Reply #19 on:
February 03, 2013, 08:41:49 pm »
You two are just too damn old to appreciate the music in the world today
Now before you judge me, know that I love Bieber, Cyrus and One Direction.
And now take me seriously, 70's Rock till the day I die
From time to time a catchy tune pops up and I DIG THE HELL OUT OF IT LOL.
Reply #20
February 03, 2013, 09:49:37 pm
Moderator
4549
Reply #20 on:
February 03, 2013, 09:49:37 pm »
Let me guess. Call ME maybe? Your fav?
To OLD?
I have original Zepplin vinyl that is nearly worn through. Wind that player again Maw.
Still enjoying, and signing music, So there you whippersnapper!!!
Reply #21
February 03, 2013, 10:43:37 pm
shorttimer
Reply #21 on:
February 03, 2013, 10:43:37 pm »
Talk about off topic!
Reply #22
February 03, 2013, 10:55:05 pm
Reply #22 on:
February 03, 2013, 10:55:05 pm »
Yes, you are on old fart. If your kids are older than me, you is olddd looool
I have read a good idea. Adding a 12v relay'd pad heater to my fuel filter for just such cases of gelling and to help warm the fuel for the first bit of a cold start.
I've got the 120A alternator, so my electrical system can handle it. That and one of
these
circulating heaters will definitely be on my upgrade list
Reply #23
February 04, 2013, 04:41:48 am
Reply #23 on:
February 04, 2013, 04:41:48 am »
I'm not sure I'd want to load the battery with a 12v heater (other than the glow plugs).
Typically, the filter should flow fuel easily enough in very cold weather, plus an inline pump there should be no issues unless the fuel is unreasonably thick from adding heavier oils. A larger bore filter setup (or two filters in parallel) would be a way to minimise fuel restriction without loading the battery more.
An engine heater is nice... the cabin gets warm fast and the start is easy.
Reply #24
February 04, 2013, 07:50:25 am
Reply #24 on:
February 04, 2013, 07:50:25 am »
Are you against loading the battery more for any particular reason? If this were a GLS TDI it would have had the glow plugs, glow plugs in the coolant line, heated seats, rear defroster on and charging the battery back up on a cold start with the same 120A alternator.
I am not too worried about frying the alt, and I have a 9 year warranty on my battery.
An engine heater seems like a way better route than a block heater. For it to be perfect, it should be able to provide like 7v to the cabin fan to run it on low while it is circulating coolant... it would keep the cabin warm and possibly even all the windows ice build-up free.
Reply #25
February 04, 2013, 08:06:35 am
Reply #25 on:
February 04, 2013, 08:06:35 am »
Only concern is the battery load before/during starting... after starting and the alternator is up, no worries.
Reply #26
February 04, 2013, 08:16:43 am
Reply #26 on:
February 04, 2013, 08:16:43 am »
Gotcha. Yes I kinda figured you probably only meant pre-start. Well Yeah, the 12v heater would only be for no start gelling issues.
Reply #27
February 04, 2013, 08:36:02 am
Reply #27 on:
February 04, 2013, 08:36:02 am »
My owners manual says that is ok to add up to 25% gasoline to diesel
if the fuel is gelling. That said maybe you could pump a couple of gallons
of gas into your tank. I don't know how you are going to mix it though.
M2 Jetta TD. Northern Missouri
Reply #28
February 04, 2013, 08:50:14 am
Reply #28 on:
February 04, 2013, 08:50:14 am »
Gotta be careful there, that manual was for Diesel 20+ years ago.. The new LSD and even newer ULSD cannot have a 25% gasoline or kerosene mixture as they could have before.
Old diesel had lots of lube, new diesel.. not so much. It will run, but for how long till your pump goes boom..?\
The tank is nearly full to the brim lol.. which is why I saw it fit to add the oil. I had a full tank of diesel with more than enough diesel additive.
Reply #29
February 04, 2013, 08:56:13 am
Reply #29 on:
February 04, 2013, 08:56:13 am »
Hi
I thought since you were running almost straight motor oil,
lubrication would not be an issue.
Pages:
General Information
General
