Author Topic: still to cold for motor oil...  (Read 12155 times)
February 03, 2013, 12:31:41 pm
« on: February 03, 2013, 12:31:41 pm »
Just an fyi lol 5 degrees celsius is still to cold to run a motor oil and diesel mix..
Fml. I had some motor oil (clean) given to me that the person never used. Being that i had roughly 35L in my tank of fresh overly additivated diesel.. I figured <10L of 5w and 10w  mixed with atf would be no big deal..
Oh how wrong!!
Reply #1February 03, 2013, 12:55:05 pm
Re: still to cold for motor oil...
« Reply #1 on: February 03, 2013, 12:55:05 pm »
Hmm it would almost appear that i have an air leak... If i leave my small electric pump on to fill the filter i can start and run it at a high idle alright un til it drains the filter.. I can see the IP pull it fast from the filter and then get swept with bubbles. Look like the ol fuel system needs an overhaul..
Reply #2February 03, 2013, 01:53:27 pm
« Reply #2 on: February 03, 2013, 01:53:27 pm »
The car will run.. It will just quickly deplete its available fuel supply and then die because of air bubbles.
So i recant, not to cokd for the mixture to run. But too cold for MY fuel system to pull it from the tank..
This fuel filter does have like.. 40k or more and like 4 years on it.. :( dohh
« Last Edit: February 03, 2013, 02:02:36 pm by 8v-of-fury »
Reply #3February 03, 2013, 01:56:58 pm
sprstu
  • 99
« Reply #3 on: February 03, 2013, 01:56:58 pm »
where would you be getting a leak pre-filter? At the firewall connection or the tank? Not many places to trouble shoot.
Mk1 caddy TD, mk4 Golf Tdi
Reply #4February 03, 2013, 02:00:32 pm
« Reply #4 on: February 03, 2013, 02:00:32 pm »
The car was originally gas and i never removed all the bs back near the tank.. Lotta places to troubleshoot haha.
Reply #5February 03, 2013, 05:46:42 pm
« Reply #5 on: February 03, 2013, 05:46:42 pm »
So basically here is my story, I am 22 and when I got this car at 17 I half-assed everything ;) Whatever, I was 17-19.. Now that I am older and exponentially more experienced, I am trying to clean everything up.. but it can only happen so fast to a daily driver I need on the road.
I have ran motor oil before (hence my confidence to dump this in my tank) in the colder weather, but I think my fuel filter is all sorts of plugged up.
Reply #6February 03, 2013, 06:10:19 pm
shorttimer
  • 121
« Reply #6 on: February 03, 2013, 06:10:19 pm »
It's so hard to relate to how cold it is there. I think the coldest I ever felt was +20F, when I was skiing. I live where the average is about +50-52F, and it's usually nice during the day. Our lowest this winter was +33F. If you're ever in these parts, you're welcome to wrench in my driveway & I'll fire up the 'barbie'.
Reply #7February 03, 2013, 06:19:21 pm
« Reply #7 on: February 03, 2013, 06:19:21 pm »
It has been 10F here consistently since two weeks ago when it was -20F.. Yes NEGATIVE 20F lmao.
CALIFORNIA, beauty place :) I do hope to make it down that way sometime in my life. I am going to hold you to that ;) lol
Reply #8February 03, 2013, 06:20:40 pm
bbob203
  • 1789
« Reply #8 on: February 03, 2013, 06:20:40 pm »
I was just in Hawaii now im in ohio...  >:(
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #9February 03, 2013, 06:30:47 pm
« Reply #9 on: February 03, 2013, 06:30:47 pm »
dude... next time i want a real pinapple from there.. the "orange" odd ball nothing in usa can replicate one...
oil too thick.. plugged up hole due to viscisity.. drain off bottom gal of fuel by pulling off tank..
Reply #10February 03, 2013, 06:56:19 pm
Dakotakid
  • 1240
« Reply #10 on: February 03, 2013, 06:56:19 pm »
"....exponentially more experienced....."
Humble as well, eh? :P
Hey, don't any of you Mk. I guys ever put a 200 watt magnetic heater on those steel fuel tanks? I used to do that a lot in cold winter when I had that vintage of junker. THAT is one thing I really miss about those earlier cars. It don't work too well wiss these plastic tanks........
Reply #11February 03, 2013, 07:16:24 pm
« Reply #11 on: February 03, 2013, 07:16:24 pm »
Haha nope, but I will be putting a torch to it tomorrow! LMAO
Reply #12February 03, 2013, 07:20:44 pm
« Reply #12 on: February 03, 2013, 07:20:44 pm »
Thrift store electric blanket  would do the trick too.
Reply #13February 03, 2013, 07:25:46 pm
« Reply #13 on: February 03, 2013, 07:25:46 pm »
I'd siphon as much as possible out the filler neck, dump a buttload of PS911 in the remainder and warm the bottom of the tank with a 400W heatlamp.
(And change the filter, duh. 4yrs?)
Reply #14February 03, 2013, 07:26:50 pm
« Reply #14 on: February 03, 2013, 07:26:50 pm »
