Author Topic: Wheel clearance + opinions  (Read 9468 times)
April 20, 2011, 06:33:05 pm
  • 3468
    • McScrubbins Body Wash
« on: April 20, 2011, 06:33:05 pm »
I have 2 sets of wheels. Stock rims with almost bald tires or aluminum offset rims with pretty meaty wide rubbers on them.
The issue is that the larger black rims & tires rub the front fenders. one side more than the other.
The passenger side rubs well before full lock steering either way. I recently replaced that fender. Could i have somehow given it less gap with how i put it on? i matched the body lines as best i could ... i didn't think it would make such a big difference.
Does anyone recommend just hammering the fender wells lip flat... because that's what i feel like doing...
Pics for good measure.
the old girl next to RadoTD's beast.
Reply #1April 20, 2011, 07:28:43 pm
  • 1739
Re: Wheel clearance + opinions
« Reply #1 on: April 20, 2011, 07:28:43 pm »
Eastwood and other companies sell a fender roller tool which bends and flares the fenders edges
Reply #2April 20, 2011, 07:53:41 pm
  • 3468
« Reply #2 on: April 20, 2011, 07:53:41 pm »
Reply #3April 20, 2011, 07:54:29 pm
« Reply #3 on: April 20, 2011, 07:54:29 pm »
My rabbit had one fender that sat closer to the tire and, of all things, it was a replacement fender installed by the PO.
I just pulled out on it and got things evened up.
I think over on the vortex I saw pics of a homemade fender roller. If you're that close what happens when you're turning and hit a bump? Wouldn't it take out the fender?
Reply #4April 20, 2011, 08:00:08 pm
  • 3468
« Reply #4 on: April 20, 2011, 08:00:08 pm »
and the tire possibly
Reply #5April 20, 2011, 09:54:13 pm
mystery3
  • 774
« Reply #5 on: April 20, 2011, 09:54:13 pm »
You can rent fender rollers in the states anyway. This question is pretty much the only thing I use whoretex for aside from the classifieds. Are those wheels 14's from an e30 with 195 or 205 rubber on them? Do you know the offset?
Reply #6April 21, 2011, 12:07:18 am
  • 3468
« Reply #6 on: April 21, 2011, 12:07:18 am »
My friend said to use a bar... in combo with a heat gun.
They are ...16s with 205s dunno the offset.
Reply #7April 21, 2011, 04:32:57 am
« Reply #7 on: April 21, 2011, 04:32:57 am »
Looks like the tire says 195/60r15   You could get a 195/40r15 and see if the lower height would help you. Those look pretty big :D
Reply #8April 21, 2011, 09:19:13 am
« Reply #8 on: April 21, 2011, 09:19:13 am »
 :o
195/60/15's are pretty huge!!
i have 185/70/r14's on my stock height mk2, and they STILL rub, and it looks jacked up..
Reply #9April 21, 2011, 03:25:18 pm
Patrick
  • 1034
« Reply #9 on: April 21, 2011, 03:25:18 pm »
I run 195/60 15's om BBS rims, mk 2 Jetta and don't have any problems. They're the right offset for a Volkswagen. I do have bigger springs in the back, but stock springs in the front. There isn't room for any more tire than it's got though.
Reply #10April 21, 2011, 03:32:44 pm
  • 3468
« Reply #10 on: April 21, 2011, 03:32:44 pm »
... I have like six inch springs. Not stock at all. I'll have to roll them or go down a size. These rims appear to have at least a half inch of offset maybe more.
Reply #11April 21, 2011, 03:47:18 pm
« Reply #11 on: April 21, 2011, 03:47:18 pm »
weird, i have 185/70/14s on my car, on some enkei 92s, et38 i think? and they are right at the edge of the fender arch.
Reply #12April 21, 2011, 07:31:04 pm
RadoTD
  • 513
    Stage WTF
« Reply #12 on: April 21, 2011, 07:31:04 pm »
If you ain't rubbin, you ain't dubbin! ;D
[/positive contribution]
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #13April 21, 2011, 07:35:01 pm
« Reply #13 on: April 21, 2011, 07:35:01 pm »
Rubbin' what? The oil pan? 8)
Reply #14April 21, 2011, 07:39:50 pm
  • 3468
« Reply #14 on: April 21, 2011, 07:39:50 pm »
the coolness of your dub is measured by the dents and scratches on your oil pan.
