Author Topic: Wheel clearance + opinions  (Read 9879 times)
Reply #15April 21, 2011, 07:48:00 pm
Re: Wheel clearance + opinions
« Reply #15 on: April 21, 2011, 07:48:00 pm »
the coolness of your dub is measured by the dents and scratches on your oil pan.
(shakes head) the only time I've hit my oil pan is when I go over a 4-5 inch rock or have the wheels sunk to the rims in mud........very annoying ::)
Reply #16April 21, 2011, 08:43:17 pm
  • 3468
    • McScrubbins Body Wash
« Reply #16 on: April 21, 2011, 08:43:17 pm »
the coolness of any mk2 is measured by how little the V-belt squeels. And thats my legitimate belief.
Reply #17April 22, 2011, 07:11:37 am
« Reply #17 on: April 22, 2011, 07:11:37 am »
Not a John Deere but I thought of you anyway. Good luck getting them not to rub.
Reply #18April 22, 2011, 08:16:56 am
Patrick
  • 1034
« Reply #18 on: April 22, 2011, 08:16:56 am »
I run 195/60 15's om BBS rims, mk 2 Jetta and don't have any problems. They're the right offset for a Volkswagen. I do have bigger springs in the back, but stock springs in the front. There isn't room for any more tire than it's got though.
weird, i have 185/70/14s on my car, on some enkei 92s, et38 i think? and they are right at the edge of the fender arch.
Tire to strut is the limiting factor on mine......
Reply #19April 22, 2011, 11:28:50 am
« Reply #19 on: April 22, 2011, 11:28:50 am »
my new GTI must be super cool then, because none of the belts make noise. its only got 2 belts (timing and alt/water pump) and neither one of them squeel.
lol  8)
Reply #20April 22, 2011, 12:47:34 pm
  • 3468
« Reply #20 on: April 22, 2011, 12:47:34 pm »
My water alt belt does. The alt pulley is smooth as glass.
Reply #21April 22, 2011, 01:12:04 pm
« Reply #21 on: April 22, 2011, 01:12:04 pm »
thats the problem right there.. my old GTI had a glazed alt pulley too.. it would squeel occasionally if you cranked the stereo up for too long..
Reply #22April 22, 2011, 07:51:14 pm
macka
  • 957
« Reply #22 on: April 22, 2011, 07:51:14 pm »
well then rough it up with some 60 grit sand paper.
Quote from: Vincent Walden
Reply #23April 22, 2011, 11:26:10 pm
trav1856
  • 230
« Reply #23 on: April 22, 2011, 11:26:10 pm »
If that's the case, I must be Miles Davis. ;-)
1981 Rabbit Diesel
1981 Cabriolet
Reply #24April 23, 2011, 09:31:56 am
« Reply #24 on: April 23, 2011, 09:31:56 am »
ive put a hole in my oil pan before.. coasted all the way down off the mountain, marking the trail i took the whole way down..
Reply #25April 23, 2011, 06:19:31 pm
  • 3468
« Reply #25 on: April 23, 2011, 06:19:31 pm »
I'm going to try and wire wheel the pulley.
Reply #26April 24, 2011, 12:00:14 pm
« Reply #26 on: April 24, 2011, 12:00:14 pm »
sand paper will work better. wire wheel wont rough it up much.. the sand paper will dig down thru the glaze..
Reply #27April 26, 2011, 09:22:37 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #27 on: April 26, 2011, 09:22:37 am »
That's what baseball bats are for.
http://www.e46fanatics.com/forum/showthread.php?t=321090
Calvin
91 VW Golf 1.6NA 5spd
