Author Topic: ive got a small fountain for a dipstick (video)  (Read 20105 times)
Reply #45April 29, 2011, 11:04:24 am
Re: ive got a small fountain for a dipstick
« Reply #45 on: April 29, 2011, 11:04:24 am »
get your block pressure situation figured out? i would be worried about that..
should pull your intake manifold and make it work likt its supposed to :thumbup:
Reply #46May 02, 2011, 12:31:21 pm
wdkingery
  • 494
« Reply #46 on: May 02, 2011, 12:31:21 pm »
hahaha no, no i have not gotten my block pressure situation figured out yet. if it's blowby (it must be cause i have good smokage when at a stoplight now that PCV is vented to atmosphere) then what am i gonna do re-ring it right now?
if the intake is just jammed up i'll deal with that ... soon hopefully.
i think it's gonna be excessive blowby tho, judging by the way it freightrains at a stoplight..
i've just got too many irons in the fire right now to really deal with the thing.
soon tho. i'll post up
Reply #47May 02, 2011, 12:37:26 pm
« Reply #47 on: May 02, 2011, 12:37:26 pm »
mine doesnt have much blow by and it still smokes at stop lights.. its a VW diesel thing.. im sure mine would puke oil too if the bottom end couldnt breathe..
only reason you never notice the smoke, is because 99.9 percent of VW diesels have properly vented breathers (vented to the intake so you never see the smoke.
why not take a compression test and see if you need rings? rather than just speculate.. because if your vents are clogged in your intake manifold, and your breather is basically a plug at that point, it will push oil out of the dipstick EVEN ON A BRAND NEW ENGINE..
make the breather work like its supposed to, and hook it up right.. then you wont have to worry about it..
Reply #48May 02, 2011, 06:05:17 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #48 on: May 02, 2011, 06:05:17 pm »
I don't think I would even consider driving around with one of those stickers on my car. Such terrible grammar :banghead:
Reply #49June 12, 2011, 08:53:07 pm
wdkingery
  • 494
Re: ive got a small fountain for a dipstick (video)
« Reply #49 on: June 12, 2011, 08:53:07 pm »
finally got around to making a video of the blowby. this is an a/c line i made into a PCV hose (to help get this stuff away from me, altho that's not working very well)
you think the intake manifold could consume all this ??
http://youtu.be/cbu9kwAztmA?hd=1
« Last Edit: June 12, 2011, 09:33:52 pm by wdkingery »
Reply #50June 13, 2011, 10:08:41 am
« Reply #50 on: June 13, 2011, 10:08:41 am »
yup, i do think it could consume all that. and i would also suspect you have a vacuum leak somewhere, or your engine has a bazillion miles on it..
Reply #51June 13, 2011, 11:20:59 am
BillyWillicker
  • 111
« Reply #51 on: June 13, 2011, 11:20:59 am »
Here is how to fix your problem;
1. Remove intake manifold
2. Clean the PCV ports in the intake manifold, if needed enlarge holes
3. Install intake manifold
4. Install new Y-hose from valve cover to intake manifold ports
5. Find and repair ALL vacuum leaks
DONE!!
Your welcome.
Jason
Reply #52June 14, 2011, 01:34:23 pm
« Reply #52 on: June 14, 2011, 01:34:23 pm »
DONE!!
Your welcome.
Jason
hes been told to do that many times.. i dont think hes considering it an option..
Reply #53June 14, 2011, 03:04:17 pm
wdkingery
  • 494
« Reply #53 on: June 14, 2011, 03:04:17 pm »
Hahahah yeeeah I've been a bit reluctant to pull the intake manifold @ this time.. wifey is goin thru immigtation, etc etc.. and I'm not sure after all that if it'll make a diff. Soon tho ladies.
Reply #54August 29, 2011, 12:02:41 pm
wdkingery
  • 494
« Reply #54 on: August 29, 2011, 12:02:41 pm »
Well guys I wobbled the holes out on my intake and the oil dipstick doesn't fountain anymore!
On a side note, my god the air conditioner brackets are bull ***! Uhhh how miserable. It's right now thi
Reply #55August 29, 2011, 12:26:18 pm
« Reply #55 on: August 29, 2011, 12:26:18 pm »
i dont mean to be an ass, and rub it in..
BUT!
WE TOLD YA SO!!
and yes, the a/c brackets are a pain.. and remember, you gotta tighten the a/c belt first, then tighten the alt..
i HATE a/c and power steering, i dont run them.. my cars all have one belt..
Reply #56August 29, 2011, 02:10:56 pm
wdkingery
  • 494
« Reply #56 on: August 29, 2011, 02:10:56 pm »
I couldn't figure a way to run just one belt. I don't even have a/c the only thing left is the compressor @ this point. But it's needed to run the alt. I tried replacin it with the alt but I couldn't go it.
How do you have one belt on an a/c car?
Reply #57August 29, 2011, 02:54:58 pm
« Reply #57 on: August 29, 2011, 02:54:58 pm »
you havent figured it out because you havent taken your a/c compressor off. and you havent found Toywagen yet..
http://www.toywagen.com/
to use stock VW pullies, you need a non a/c crank pulley and water pump pulley.. then the stock alternator pulley lines up perfectly.
only reason i know that, is because ive compared a/c pulleys, and non a/c pullies.. the a/c pulleys have more offset (1 belt width)
Reply #58August 29, 2011, 03:07:47 pm
wdkingery
  • 494
« Reply #58 on: August 29, 2011, 03:07:47 pm »
No dude my bolts were stripped that hold the compressor to the bracket so I had to pull it all down; the alt, compressor both brackets everything. (turns out that bracket holds coolant too! Big surprise there)
But I didn't have access to the non a/c pullies yeah I'm dyin to get this damn compressor off.
Next time it dicks off again I'll find these pullies you speak of.
Reply #59August 29, 2011, 03:17:28 pm
« Reply #59 on: August 29, 2011, 03:17:28 pm »
toywagen makes a pulley where you can use all the pullies you already have on your engine..
and no, the bracket doesnt have any coolant running thru it. but the bolts that hold that bracket on, also hold the water pump to the block.. THAT has coolant in it, not the bracket..
