Author Topic: ive got a small fountain for a dipstick (video)  (Read 20074 times)
Reply #30April 19, 2011, 11:34:10 am
wdkingery
  • 494
Re: ive got a small fountain for a dipstick
« Reply #30 on: April 19, 2011, 11:34:10 am »
"style of airbox"
"the trick-hood chimney effect"
what happens if i even partially cover the valve cover hole (this is the same effect i get if i run my PCV in the stock configuration)
Reply #31April 19, 2011, 01:03:13 pm
« Reply #31 on: April 19, 2011, 01:03:13 pm »
"style of airbox"
first picture:
those tubes with bolts in them, those are for the breather off the top of the valve cover.. hook up the breather line from the valve cover to those hoses. either find the right hose, or just get a T and some hose and make your own..
if it just blows oil out the dip stick tube even with the breather hooked up to the intake, then you have clogged ports in the intake manifold.. there have already been a few different people telling you to clean out the crud from those ports and hook it up like it should be..
Reply #32April 19, 2011, 01:07:50 pm
Mark(The Miser)UK
  • 1557
« Reply #32 on: April 19, 2011, 01:07:50 pm »
You have to make do with what you have; put a hole through your hood, stick on a stack and a pietzo electric igniter.
If it burns, it's rings, and if it doesnt, then its valve stem seals [maybe] ;D
Mark-The-Miser-UK
Reply #33April 19, 2011, 01:57:28 pm
wdkingery
  • 494
« Reply #33 on: April 19, 2011, 01:57:28 pm »
Mark you flippin crack me up!
Reply #34April 19, 2011, 03:33:11 pm
Mark(The Miser)UK
  • 1557
« Reply #34 on: April 19, 2011, 03:33:11 pm »
I couldn't think of anything constructive to add...  H'mm; perhaps use kerosine to clean out the gauze in the valve cover ;D.
Mark-The-Miser-UK
Reply #35April 20, 2011, 10:19:23 am
« Reply #35 on: April 20, 2011, 10:19:23 am »
^^^do that^^^
lol, that should be big enough for EVERYONE to see. haha
Reply #36April 20, 2011, 09:03:02 pm
  • 4553
« Reply #36 on: April 20, 2011, 09:03:02 pm »
Never did get Fatmobile to respond to drilling into the intake manifold.  Anyone care to speculate on what he was trying to say.  I know there are four small holes in the bottom of the box, Was he thinking to enlarge them or was he even thinking?
My 81 is starting to build oil in the box and smokes at idle.  Pinch the hose from the VC and watch that dipstick jump right up into your hand.  Very amusing to small children in the neighborhood.  You can kind of figure out when to command it out based on time and idle.
Reply #37April 20, 2011, 10:02:25 pm
« Reply #37 on: April 20, 2011, 10:02:25 pm »
Pinching the breather will pressurize the block.
In the OP's picture, if you pull the hoses with bolts stuck in the end of 'em and look down in there you'll see how it necks way down. Looks like one of vdub's engineers wasn't wearing his thinkin' cap right then.
The port goes into a much larger one that splits into each runner. I just looked at mine (off of vehicle) and it looks like you could drill it out bigger thus eliminating some oil leaks due to lower block pressure.
Also those restrictors could be plugged with something.
A properly vented block WILL NOT push oil out the dipstick tube without very major blowby and then every seal on it would most likely leak pretty bad.
Reply #38April 20, 2011, 10:41:20 pm
  • 2932
« Reply #38 on: April 20, 2011, 10:41:20 pm »
Drill out the restrictors is basically the same thing others are saying.
The post just before this explains it well.
Reply #39April 25, 2011, 09:22:33 pm
  • 4553
« Reply #39 on: April 25, 2011, 09:22:33 pm »
In context it makes sense.  To just say "Drill out the restrictors" kind of leaves one to scratch, well what ever.  Thanks for the clarification
Reply #40April 26, 2011, 09:23:24 am
« Reply #40 on: April 26, 2011, 09:23:24 am »
un clog the damn manifold so it can function properly.. that should be pretty straight forward. shouldnt have to think too much on that one either.. lol.
Reply #41April 26, 2011, 08:33:01 pm
wdkingery
  • 494
« Reply #41 on: April 26, 2011, 08:33:01 pm »
sorry guys i've also hacked my new AT&T inspire 4g to run on gingerbread so i'm worrying those forum members over there, and my 05 mustang GT has a parasitic draw so i'm worryin those guys in that forum, and i just got a Garrett AT Pro metal detector so i'm worryin that forum called treasurenet.com about it ..
and it's gonna be exam week next week
and the stupid race is in town this weekend so i gotta get ready for that
i think the restrictors just need to be drilled out (hahaha sorry i couldn't help it)
i think that one rabbitman is right; the motor shouldn't push the dipstick out even if it was all slopped out (which mine very well could be given my PROTHE compression gauge results)
but i have decided to keep it vented to atmosphere, cause it .. kinda adds to the .. beauty of the car. like when i stop, i also smoke and it makes the hippies and the liberals whine even more.
oh, i guess i should clarify why they are whinin to begin with:
so the smoke tends to help my cause haha
i've got a whole bunch more in my window now but it's dark and it's late i'm not runnin down to snap one off.
hey i got a blinkin glowplug light.. if i drain the water and nothing comes out or the light dont stop blinkin should i snip the wires?
« Last Edit: April 26, 2011, 08:34:36 pm by wdkingery »
Reply #42April 26, 2011, 08:42:29 pm
maxfax
  • 2126
« Reply #42 on: April 26, 2011, 08:42:29 pm »
You're referring to that nice little MK2 water separator??  Clip the wires and when time permits eliminate the whole darned troublesome thing..
Reply #43April 27, 2011, 08:34:28 pm
wdkingery
  • 494
« Reply #43 on: April 27, 2011, 08:34:28 pm »
Well drained some water I think? It alternated between brown river water and what appeared to be clean diesel..? Is this thing working or is there a way to  tell?
The light stopped blinking
Reply #44April 29, 2011, 09:22:41 am
jseeley
  • 106
« Reply #44 on: April 29, 2011, 09:22:41 am »
Sounds like you did it correctly; The light comes on when water completes the circuit. If it's off now then you should be good. My light wasn't blinking, but the moment I touched my rear water separator it fell apart, so I just ripped it out. There was some pretty nasty stuff in there though.
85 Golf Diesel 1.6 NA 240K miles? (odometer broken)
87 Cabriolet 1.8 Gasser 104K miles
05 Golf 2.0 Gasser 66k miles
03 Jetta Wagon TDI 112k Miles
