Author Topic: ive got a small fountain for a dipstick (video)  (Read 20099 times)
Reply #60August 30, 2011, 04:55:08 am
92EcoDiesel Jetta
Re: ive got a small fountain for a dipstick (video)
« Reply #60 on: August 30, 2011, 04:55:08 am »
ROR, are u using that toywagen pulley on your diesel? It is designed for the gas engines. Will it have the correct offset for diesels, especially mine? What about pulley diameter? Is it the same?
Reply #61August 30, 2011, 11:25:00 am
« Reply #61 on: August 30, 2011, 11:25:00 am »
8v, and diesel should have the same offset pulley. it should be the bracket that is different..
Reply #62August 30, 2011, 11:49:25 am
92EcoDiesel Jetta
« Reply #62 on: August 30, 2011, 11:49:25 am »
R U saying in addition to the Toywagen pulley, I also need the adjusting bracket from a gasser to convert my Ecodiesel to AC less? With a new longer belt of course.
Reply #63August 30, 2011, 11:56:46 am
« Reply #63 on: August 30, 2011, 11:56:46 am »
no, im saying that you need a mk2, non-a/c mount for a diesel.. the gasser mount will have the alt in the WRONG spot..
Reply #64September 04, 2011, 07:36:43 pm
« Reply #64 on: September 04, 2011, 07:36:43 pm »
I swapped a non-AC alt pulley on to a non-AC alt (the mounting ears are different), dropped my compressor off as scrap metal and then got the VW non-AC brackets and bolts.  That way I can always get parts that fit without having to fab anything down the road.  No issues with alignment, no issues with belts.
Reply #65September 05, 2011, 05:18:40 pm
« Reply #65 on: September 05, 2011, 05:18:40 pm »
no, there not.. there is a complete a/c alternator on my 86 golf.
the brackets are different, not the alternator and pulley..
the mounting ears on the non-a/c alt were no different than the big 90a a/c alt i swapped on my car..
Reply #66September 05, 2011, 05:56:14 pm
« Reply #66 on: September 05, 2011, 05:56:14 pm »
Sorry Kevin but the mounting points are different on the AC vs non AC alternators. The top pivot one is the same but the lower one is different. Actually the top one might be different as well I'm not 100% sure now. I have held both in my hands and you can clearly see they are different. I thought I have a picture but I don't.
Reply #67September 05, 2011, 06:52:39 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #67 on: September 05, 2011, 06:52:39 pm »
The ear position on a factory AC equipped MKII alternator is the same as a gasser. It is different than a non AC diesel MKII.
Reply #68September 05, 2011, 10:38:07 pm
« Reply #68 on: September 05, 2011, 10:38:07 pm »
Trust me, they're different.  I had to buy a new alt I otherwise didn't need to get the brackets to work.  I definitely tried to use the one I had first only to find it didn't fit the bracket at all.
The diesel non-AC alt has the mirror image of the gasser / diesel AC mounting ears - they are exactly the same size, shape, etc just exactly opposite in where they sit on the alternator.  If I made my own bracket and was happy to have a non-standard belt size I could have used my AC alt, but I wanted to be able to walk in to a parts store in the middle of nowhere and get parts by number rather than messing around trying to fit bodged together components.  Besides it was starting to get noisy.
Reply #69September 05, 2011, 11:15:13 pm
« Reply #69 on: September 05, 2011, 11:15:13 pm »
i got lucky then.. because i have an 86 GTI (golf conversion) that is factory non a/c, non p/s car.. it had a tiny little 65 amp alternator..
i didnt change ANYTHING besides the wiring, because the 65a had a plug with 3 wires, and the 90a had 2 separate wire.
anyways, pulled the 90a off a GTI w a/c & p/s.. still had the pulley on it from the a/c belt setup. bolted it right on the non a/c
crap, i forgot that diesels have different positions for the alternator if its got a/c or not.. i forgot that they place them up REAL HIGH like on a gasser. and down low for non a/c..
sorry guys, my bad, i was wrong..
Reply #70September 06, 2011, 09:30:22 pm
  • 4553
« Reply #70 on: September 06, 2011, 09:30:22 pm »
I guess we can forgive you.  Depends on how much corner time you are willing to do.  Or would you rather write something like 500 times.  Remember when they used to do that stuff?
Reply #71September 06, 2011, 09:49:08 pm
« Reply #71 on: September 06, 2011, 09:49:08 pm »
i DO remember when they used to do that stuff..
they dont anymore, and it shows.. kids are hellions now days..
