Author Topic: The old blue rebuild (1983 1.6 TD)  (Read 83859 times)
Reply #105March 19, 2011, 08:40:19 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
Re: The old blue rebuild (1983 1.6 TD)
« Reply #105 on: March 19, 2011, 08:40:19 am »
does anyone know?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #106March 20, 2011, 09:00:26 pm
Baron VonZeppelin
« Reply #106 on: March 20, 2011, 09:00:26 pm »
NA 130-135
TD 155
Time to NA specs with NA injectors.
If you're going to get new/rebuilt injectors - go ahead and get the right pop pressure ones. The engineers surely had good reasons for making the TD a higher opening pressure and higher timing.
I think prothe still sells them for 100-125 set of 4 - new.
Never used them before.
But he offers 2 year warranty on them now.
Reply #107March 20, 2011, 09:37:00 pm
dankcorey22
  • 379
    Cummins!
« Reply #107 on: March 20, 2011, 09:37:00 pm »
NA 130-135
TD 155
thats a reason to try prothes injectors then. i can be ginny pig  ;) i have a lot of 130 bars sitting around my house but i want to go with oem specs.
Reply #108March 31, 2011, 07:10:33 pm
Stix212
  • 11
« Reply #108 on: March 31, 2011, 07:10:33 pm »
wow
Reply #109March 31, 2011, 07:17:55 pm
dankcorey22
  • 379
    Cummins!
« Reply #109 on: March 31, 2011, 07:17:55 pm »
wow
flip it up side down it says "mom"
What about it?
Reply #110March 31, 2011, 08:19:23 pm
Baron VonZeppelin
« Reply #110 on: March 31, 2011, 08:19:23 pm »
What about it?
Stix must have seen the pictures of those Prothe injectors.
oops
lol damn those things were wacky
Reply #111March 31, 2011, 09:12:08 pm
dankcorey22
  • 379
    Cummins!
« Reply #111 on: March 31, 2011, 09:12:08 pm »
lol i guess so... i guess i was the ginny pig someones got to do it  :-[
Reply #112May 22, 2011, 09:45:32 am
dankcorey22
  • 379
    Cummins!
« Reply #112 on: May 22, 2011, 09:45:32 am »
Ive done a little bit more to my motor. All im waiting on now is my head from the machine shop! And i need to get a head gasket also.
Reply #113May 22, 2011, 10:17:29 am
« Reply #113 on: May 22, 2011, 10:17:29 am »
Im looking for some new injectors now. I gotta get something stright before i buy some
1.6 td - 155bar
1.6 na- 130bar or 135bar
1.5 na- 115 bar ?
Im probably totally off but would someone correct me.
 And can i run 1.6 na injectors in my 1.6 td? I think the answer to that question is yes but i have to time the IP to 1.6 NA Correct?
time your pump to whatever injectors you are running..
and ORIGINAL 1.5 injectors were 180bar, and had a timing spec of 1.15mm..
the 155bar injectors atomize fuel better..
im running n/a injectors in my engine, with 15 psi..
Reply #114May 22, 2011, 01:12:53 pm
dankcorey22
  • 379
    Cummins!
« Reply #114 on: May 22, 2011, 01:12:53 pm »
I got some 155 bar ill probably go alittle above 1 its been awhile since ive looked how to time these things. Ive never timmed on of the mech. ones before. Ive always done the TDI's
Reply #115May 24, 2011, 06:15:41 am
JessaBug
  • 112
« Reply #115 on: May 24, 2011, 06:15:41 am »
Vince Walden has a great how-to for the timing. We have a copy we keep with our timing tools.
Mine - BMP 20thAE GTI
His - '01 Jetta TDI
Our project: '84 Jetta TD
Reply #116May 24, 2011, 07:45:34 am
dankcorey22
  • 379
    Cummins!
« Reply #116 on: May 24, 2011, 07:45:34 am »
I have that page my under my favorites haha thats a good how-to!
Reply #117September 02, 2011, 07:02:10 am
dankcorey22
  • 379
    Cummins!
« Reply #117 on: September 02, 2011, 07:02:10 am »
Finally got my head back from the machine shop.. After 3 months so here she is
straping down the head
Reply #118September 02, 2011, 07:04:37 am
dankcorey22
  • 379
    Cummins!
« Reply #118 on: September 02, 2011, 07:04:37 am »
All Timed up! timing belt on and ready to rock and roll! i put the timing at .040 i think that will be fine.
Im leaving for the beach one last time this year so ill be posting back pics when i come back up Monday.
Reply #119September 02, 2011, 07:12:09 am
« Reply #119 on: September 02, 2011, 07:12:09 am »
sadly i see 2 flaws..
1st... turbo in way to get manifold bolts tight on intake..
2nd.. timming belt tensioner is wrong direction.. gotta lift up on it vs down on old 1.6.. the lower cover is in the way the way you have it..
