Author Topic: The old blue rebuild (1983 1.6 TD)  (Read 83784 times)
Reply #120September 02, 2011, 11:24:24 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
Re: The old blue rebuild (1983 1.6 TD)
« Reply #120 on: September 02, 2011, 11:24:24 am »
sadly i see 2 flaws..
1st... turbo in way to get manifold bolts tight on intake..
2nd.. timming belt tensioner is wrong direction.. gotta lift up on it vs down on old 1.6.. the lower cover is in the way the way you have it..
Thanks man ill fix that right up when i get back home! but i got the intake bolts pretty tight with the turbo and exhaust on first.. I got all kinds of swivels
Thanks  ;D
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #121September 03, 2011, 04:58:16 pm
Thezorn
  • 381
« Reply #121 on: September 03, 2011, 04:58:16 pm »
Just put the intake on first and torque it down, then the turbo on second.
Just a thought.
Compounded 93 AAZ
Reply #122September 06, 2011, 03:49:23 pm
dankcorey22
  • 379
    Cummins!
« Reply #122 on: September 06, 2011, 03:49:23 pm »
Does someone on the forums have a picture of the front of their TD engine after all the coolant hoses are on. I cant exactly remember how they go and my pictures arnt that great from that angle.
This is what i need with ALL hoses attached
Reply #123September 06, 2011, 10:31:23 pm
dankcorey22
  • 379
    Cummins!
« Reply #123 on: September 06, 2011, 10:31:23 pm »
Thanks for all the replies guys!  :P But i figured it out
Only need hose clamps Alt. Belt and i need to make my down pipe Then she'll be ready to start putting in the car.
The down pipe will probably take forever!
Reply #124September 09, 2011, 07:06:50 am
dankcorey22
  • 379
    Cummins!
« Reply #124 on: September 09, 2011, 07:06:50 am »
Started making my down pipe yesterday and got the engine in the car late last night. Anyways heres some pics. tell me what ya think, or if you see anything i did wrong, feel free to correct me please
Reply #125September 09, 2011, 07:13:47 am
92EcoDiesel Jetta
« Reply #125 on: September 09, 2011, 07:13:47 am »
Nice! What diameter is your down pipe and is it stainless?
Reply #126September 09, 2011, 07:16:41 am
dankcorey22
  • 379
    Cummins!
« Reply #126 on: September 09, 2011, 07:16:41 am »
Its a 2.5" and its not stainless i wish it was! But im on a budget here lol Plus i dont have a TIG.
I hope it fits good till the tunnel then im taking it to a muffler shop. Cause i dont have a lift
Reply #127September 09, 2011, 10:54:22 am
92EcoDiesel Jetta
« Reply #127 on: September 09, 2011, 10:54:22 am »
I've heard of someone using a down pipe from a Mercedes W123 turbodiesel (plenty full in junkyards) that is stainless and has a flex section built in and welded it up to the toilet bowl. It is at least 2.25" o.d. and may be 2.5" o.d. I have one and will measure it and report back and shoot a pic of it.
« Last Edit: September 09, 2011, 10:59:23 am by 92EcoDiesel Jetta »
Reply #128September 09, 2011, 06:00:26 pm
dankcorey22
  • 379
    Cummins!
« Reply #128 on: September 09, 2011, 06:00:26 pm »
Ive never heard of that but i would like to see a pic if you got some!
Reply #129September 11, 2011, 07:34:25 am
dankcorey22
  • 379
    Cummins!
« Reply #129 on: September 11, 2011, 07:34:25 am »
Does anyone know which wire is hot coming from the key cylinder? I need it to be hot when i turn the key to ON position.  I need them for my gauges.
I thought i might check here before checking later tonight.
Thanks
Reply #130September 11, 2011, 06:26:06 pm
dankcorey22
  • 379
    Cummins!
« Reply #130 on: September 11, 2011, 06:26:06 pm »
Reply #131September 11, 2011, 08:12:48 pm
« Reply #131 on: September 11, 2011, 08:12:48 pm »
shift linkage and down pipe seem to have issue in the one pic..
Reply #132September 11, 2011, 08:58:12 pm
dankcorey22
  • 379
    Cummins!
« Reply #132 on: September 11, 2011, 08:58:12 pm »
I think it was just the way i took the picture but the DP is far from the linkage.
Does anyone know of how to get the CV axle into place with out removing the ball joint and tie rod end? Just asking. Im going to do that tomorrow, They were in the way when i was placing the engine so i let them both fall
Reply #133September 12, 2011, 11:46:26 am
92EcoDiesel Jetta
« Reply #133 on: September 12, 2011, 11:46:26 am »
Here's pic of the Mercedes downpipe. It is 60 mm o.d with a flex section. I think for someone who can fab and weld, it could be adapted to go direct to the turbo flange and elimiate the toilet bowl altogether.
« Last Edit: September 12, 2011, 12:29:12 pm by 92EcoDiesel Jetta »
Reply #134September 12, 2011, 08:45:57 pm
dankcorey22
  • 379
    Cummins!
« Reply #134 on: September 12, 2011, 08:45:57 pm »
Somebody could definetly get that thing to work. Thanks for the pic man!
