Author Topic: The old blue rebuild (1983 1.6 TD)  (Read 83789 times)
Reply #90August 04, 2010, 05:52:33 am
Re: The old blue rebuild (1983 1.6 TD)
« Reply #90 on: August 04, 2010, 05:52:33 am »
286 2nd Avenue
Tiffin, OH 44883-1327
(419) 443-8987
The guy is named John. Great guy. Same that did my head. I think I had 500.00 shipped both ways for full port and polish, SS valves, flowbench tested, and complete rebuild. If you didn't get port, polish, and flowbench I bet it would be at least 100 cheaper
Reply #91August 04, 2010, 06:33:51 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #91 on: August 04, 2010, 06:33:51 am »
I didnt know that it wouldnt cost with it before i walked out, believe me if i did i would have walked out with everything on that head lol
see the problem with doing it my self is i dont have any valve spring compressors  :-\ or i would do all of the work myself
Ill keep Toms number in my phone just
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #92August 04, 2010, 06:35:57 am
dankcorey22
  • 379
    Cummins!
« Reply #92 on: August 04, 2010, 06:35:57 am »
286 2nd Avenue
(419) 443-8987
 See the only problem with him is i got to ship  the head, the guy Baron is talking about he is 15Mins away from me, I know he is probably really good but its just much easier to take it 15MIN
Reply #93August 04, 2010, 09:14:21 am
Baron VonZeppelin
« Reply #93 on: August 04, 2010, 09:14:21 am »
The order i listed of things to do to the head weren't in chronological order. It was late and the pillow was calling me with a real convincing tone.
If you're gonna do the precups, do them first.
And it might would require pro machining to deck the surface after they are staked in place. I've never gotten involved with precups.
I'm beginning to wonder if the upgrade they did for TD precups might have been instituted across the board on all precups. Wonder if there are part numbers that can be referenced to distinguish ?
As nice as that head is, majority on these boards would do the block sanding and hand lapping (with your TD valves) and go right ahead forward with it using new valve guide seals.
Its understandable if you don't have access or are more comfortable having it done by someone else. They'll probably clean it nice, check spring pressures, check valve giude clearances, install the guide seals (supposed to be a bit of a bicht), and hopefully re-shim the cam/lifter clearances if needed. Tom is the #1 go-to-guy around here. He was born in a VW, and hasn't left them since. His ol man is same way. They have connections when/where needed.
Reply #94August 04, 2010, 12:48:26 pm
dankcorey22
  • 379
    Cummins!
« Reply #94 on: August 04, 2010, 12:48:26 pm »
Im going to do the precups when i have time but at this point in my life im pretty busy with everything about moving to college and getting everything ready and trying to find a job down in wilmington, plus getting my car back togather. so give me some time but everything will come back together eventually  ;) right i hope!
But open to tips and what yall think also
Baron- im am comfortable doing the head myself its just i dont have the proper tools to do get it done right. Ill take it to Tom when i get around to it, you talk like he is the best around, and i bet he is! ill mention you sent me maybe he will knock some change off lol
I always hand lap every engine ive rebuilt, i dont know of any other way of doing it.
I wish someone would chime in that knows alot of the precups, do the TD and NA have different parts numbers?
Reply #95August 06, 2010, 03:31:39 pm
dankcorey22
  • 379
    Cummins!
« Reply #95 on: August 06, 2010, 03:31:39 pm »
heres the differences in the head that i have.
Heres the cracked one the original one.
Heres the new one
the cracked one
The new one
 I dont think any of this would matter but im just showing it to yall folks
Reply #96August 07, 2010, 01:59:36 pm
Baron VonZeppelin
« Reply #96 on: August 07, 2010, 01:59:36 pm »
I think the consensus around here is  ... we don't have too much rhyme or reason behind the suffix following 373 on the heads.
Just to compound that - i have a complete 85 TD engine that appears to be unaltered. The head is 373 M.
Same as your 85 NA replacement head.
My 85 TD-GL was a two owner car and not a bolt nut or bracket missing. The head is 373 N.
The 82 12mm engine in my 81 Truck has a 373 B head.
The 2 Hydra TD engines are both 373 T heads.
I've asked Bill to get the number from his 84 TD head.
Reply #97March 11, 2011, 11:53:55 pm
dankcorey22
  • 379
    Cummins!
« Reply #97 on: March 11, 2011, 11:53:55 pm »
Okay Im back for a week (spring break) So this is what i have done this week workin a little here and there...
Cleaned the Block and painted it black.
Put the crank in and torqued the main bolts down
slid the pistons in very carefully lol i was afraid i would hit the squirter. I didnt replace the Connecting rod nut (bolt) What the Bentley says i guess it will be fine. I didnt quite understand what they said to replace the stud or nut?
Does anyone know what this gasket goes to?
I will resume for good this May with my engine...
Reply #98March 12, 2011, 12:13:30 am
coke
  • 254
« Reply #98 on: March 12, 2011, 12:13:30 am »
That gasket on the bottom looks like the dual outlet exhaust manifold gasket.  I've never seen a diesel with a duel outlet manifold, but my gas 1.8 has one. It is safe to discard it.
Reply #99March 12, 2011, 12:18:34 am
dankcorey22
  • 379
    Cummins!
« Reply #99 on: March 12, 2011, 12:18:34 am »
thanks man. you want it? pay for shipping and ill give it to you!
Reply #100March 12, 2011, 12:40:13 am
coke
  • 254
« Reply #100 on: March 12, 2011, 12:40:13 am »
All set. I sold that piece of crap for 250 bucks. I'm waiting on the guy to come get it.  I needed a car for my wife last year and it was available for 1500 and had "all kinds of work" done to it. Yeah, it had about 6 washers stacked on the clutch cable as spacers, and it was a manual cable vs the auto adjust. The exhaust mani leaked, and the brake lines and proportioning valve were a solid mass of rust.  So I don't need a gasket for it, haha. ;)
Reply #101March 12, 2011, 08:54:13 am
dankcorey22
  • 379
    Cummins!
« Reply #101 on: March 12, 2011, 08:54:13 am »
haha i hear you it a dumb gasser anyways....
Reply #102March 12, 2011, 09:34:56 am
macka
  • 957
« Reply #102 on: March 12, 2011, 09:34:56 am »
I don't have a compressor either. I used an 8 inch clamp and a O2 sensor to get the head disassembled.
Quote from: Vincent Walden
Reply #103March 16, 2011, 11:28:44 am
dankcorey22
  • 379
    Cummins!
« Reply #103 on: March 16, 2011, 11:28:44 am »
Im Just going to leave the head to the professionals...
Reply #104March 16, 2011, 07:49:08 pm
dankcorey22
  • 379
    Cummins!
« Reply #104 on: March 16, 2011, 07:49:08 pm »
Im looking for some new injectors now. I gotta get something stright before i buy some
1.6 td - 155bar
1.6 na- 130bar or 135bar
1.5 na- 115 bar ?
Im probably totally off but would someone correct me.
 And can i run 1.6 na injectors in my 1.6 td? I think the answer to that question is yes but i have to time the IP to 1.6 NA Correct?
