Author Topic: The Rebirth of Smokey Eddy - The 1.9 Saga  (Read 54263 times)
Reply #30May 22, 2010, 08:14:06 pm
Re: The Rebirth of Smokey Eddy - The 1.9 Saga
« Reply #30 on: May 22, 2010, 08:14:06 pm »
SExyness ;)
Reply #31May 23, 2010, 11:45:23 am
  • 3468
    • McScrubbins Body Wash
« Reply #31 on: May 23, 2010, 11:45:23 am »
so upon pulling the old block out i've found a tooth missing on the flywheel. My friend said i have to get it machined for the new clutch anyways and that i should find one at a wrecker but the amount of work to pull the block out of the tranny and the likely hood of finding one is so low.
so i guess i'll get a new one?
Reply #32May 24, 2010, 08:09:49 pm
  • 3468
« Reply #32 on: May 24, 2010, 08:09:49 pm »
mine is just missing a tooth.. do you think that's a big deal? it only has to do with starting... and i never noticed an issue.
Reply #33May 24, 2010, 08:11:12 pm
« Reply #33 on: May 24, 2010, 08:11:12 pm »
you've probably just always been lucky enough that portion never came around while starting.. lmao
However, if it is only one tooth.. it couldn't be too much a problem
Reply #34May 24, 2010, 08:26:22 pm
« Reply #34 on: May 24, 2010, 08:26:22 pm »
The cheap guy in me would just weld it back on and grind it down. :D
Reply #35May 24, 2010, 08:28:05 pm
  • 3468
« Reply #35 on: May 24, 2010, 08:28:05 pm »
the tooth? the tooth is missing...
i think i'll remove a tooth on the opposite side for balancing.
There is no marring on the starter at all. and for the hundreds of times it's started the starter must have passed the missing tooth.
Reply #36May 25, 2010, 03:36:01 pm
  • 3468
« Reply #36 on: May 25, 2010, 03:36:01 pm »
my oil cooler sandwich plate thing!
Just look at the blue-ing on that pressure plate. It's not hard to tell it had slipped a few times at high speed.
There is almost no friction material left on this clutch. its alllmosttt metal on metal
Reply #37May 25, 2010, 03:45:29 pm
« Reply #37 on: May 25, 2010, 03:45:29 pm »
Look at my thread dude LOL. The floor was gone. I would wire weld a glob on there and grind a "new" tooth into shape.
Reply #38May 25, 2010, 05:21:59 pm
81 vw pu
« Reply #38 on: May 25, 2010, 05:21:59 pm »
Is the tooth broken off all the way through, or just chipped on the starter side? I have heated the starter ring gear, removed, and flipped so the good side faces the starter. If you have another trashed flywheel with a good starter ring gear you could just swap the ring gears. Maybe even buy a new ring gear as a last resort.
Reply #39May 25, 2010, 09:03:54 pm
  • 3468
« Reply #39 on: May 25, 2010, 09:03:54 pm »
The tooth is totally missing. But i never noticed anything ever when starting ... the only concern is balancing...
i guess when i take it to get resurfaced i'll see what they say. i'm going to europe for 2 weeks so i'll be idle for the next 18 days.
Reply #40May 25, 2010, 09:07:37 pm
macka
  • 957
« Reply #40 on: May 25, 2010, 09:07:37 pm »
bring me back a sacher torte
Quote from: Vincent Walden
Reply #41May 25, 2010, 09:09:20 pm
  • 3468
« Reply #41 on: May 25, 2010, 09:09:20 pm »
if my ... very limited foreign language knowledge serves me well... is that not a chocolate cake or pastry or something?
Reply #42May 25, 2010, 09:14:07 pm
macka
  • 957
« Reply #42 on: May 25, 2010, 09:14:07 pm »
yessir, it is a rare treat. For some reason they never taste quite the same as they do in Europe.
Reply #43May 25, 2010, 09:15:57 pm
  • 3468
« Reply #43 on: May 25, 2010, 09:15:57 pm »
I think its just going to be England & Spain. No germany. =P
My family lives in England. Maybe i'll bring back a V6 tdi ;) with 24 valves
Reply #44May 25, 2010, 09:30:41 pm
macka
  • 957
« Reply #44 on: May 25, 2010, 09:30:41 pm »
then let me know how much a 1# bag of army and navy boiled sweets are and I'll paypal you the $$. Can't get em here for love nor money.
