Author Topic: The Rebirth of Smokey Eddy - The 1.9 Saga  (Read 54613 times)
Reply #15May 17, 2010, 07:26:50 pm
Re: The Rebirth of Smokey Eddy - The 1.9 Saga
« Reply #15 on: May 17, 2010, 07:26:50 pm »
Weight increase between the two engines shouldn't be that much more.. Can't be more then 75lbs.. It may handle a little heavier upfront with that much extra though.
Reply #16May 17, 2010, 11:57:23 pm
RadoTD
  • 513
    Stage WTF
« Reply #16 on: May 17, 2010, 11:57:23 pm »
1.9 > 1.6.
^^ Mathematical proof :D
I'm pretty interested to see the findings!
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #17May 21, 2010, 12:59:05 pm
macka
  • 957
« Reply #17 on: May 21, 2010, 12:59:05 pm »
no fluids in a 1.9 comes in at 256 lbs according to a shipping company http://forums.tdiclub.com/showthread.php?t=190201
Quote from: Vincent Walden
Reply #18May 21, 2010, 01:10:53 pm
  • 3468
    • McScrubbins Body Wash
« Reply #18 on: May 21, 2010, 01:10:53 pm »
That must be a complete engine though. or at LEAST tall block...
the block of the 1.9 is very marginally taller... it can't be much more
Reply #19May 21, 2010, 01:19:01 pm
  • 3468
« Reply #19 on: May 21, 2010, 01:19:01 pm »
i wish SO badly that i could have dyno'd the 1.9/1.6...
Im sure it was a much faster car than my heavier 2-dr 2000 TDI ALH golf.
« Last Edit: May 21, 2010, 01:27:42 pm by Smokey Eddy »
Reply #20May 21, 2010, 03:26:15 pm
« Reply #20 on: May 21, 2010, 03:26:15 pm »
On the scales all packed up a 1.9 block with all the guts weighs right around 160 lbs.
As I recall last time I had a 1.6 block all packed up it was 150 pounds.
Reply #21May 21, 2010, 04:07:56 pm
fck
  • 70
« Reply #21 on: May 21, 2010, 04:07:56 pm »
what in the hole?
what happened to this thing?
Reply #22May 21, 2010, 06:08:44 pm
  • 3468
« Reply #22 on: May 21, 2010, 06:08:44 pm »
what in the hole?
I think i understand what you're saying.
One of the connecting rods came free of the crank and the rod was pushed through the side of the cylinder block.
Reply #23May 21, 2010, 06:09:37 pm
  • 3468
« Reply #23 on: May 21, 2010, 06:09:37 pm »
yeah so +10 pounds which isn't a lot. that's all probably piston head & counter weight too.
Reply #24May 21, 2010, 09:04:15 pm
fck
  • 70
« Reply #24 on: May 21, 2010, 09:04:15 pm »
what in the hole?
sorry, i was feeling a bit punny earlier.
i can't imagine the noises this kind of thing would make whilst happening.
look forward to your progress!
Reply #25May 22, 2010, 01:30:57 am
  • 3468
« Reply #25 on: May 22, 2010, 01:30:57 am »
It was surprisingly quiet. most of the noise was the bits hitting the underneath of the car. the engine still idled fine on 3 cylinders but this was all already in a thread that has come and gone.
Reply #26May 22, 2010, 03:11:48 pm
  • 3468
« Reply #26 on: May 22, 2010, 03:11:48 pm »
These things are supposed to handle an unreal amount of torque...
My Magnetic sensor. Hopefully this will drive the tach i have. (special Thanks to RadoTD)
My Clutch came with one of these and so did my transmission rebuild package (special thanks to VinceWaldon)
My second grouping of parts. This time more transmission related.
Except for the timing belt, tensioner, magnet sensor & water pump with T-stat.
It's an 80C t-stat because i've heard of over heating issues with the aaz. I also anticipate this summer to be a scorcher along with at least 1 trip through the rockies. I have a winter 87C t-stat and now a summer 80C t-stat. :)
« Last Edit: May 22, 2010, 03:25:48 pm by Smokey Eddy »
Reply #27May 22, 2010, 03:23:11 pm
macka
  • 957
« Reply #27 on: May 22, 2010, 03:23:11 pm »
Eddy quit flashing your clutch.  ;D  Is it wrong to say I had it in my hands?
Reply #28May 22, 2010, 03:24:08 pm
  • 3468
« Reply #28 on: May 22, 2010, 03:24:08 pm »
Isn't it sexy. It's surprisingly small. i was shocked at how tiny it actually is. It's about the size of a dinner plate.
Reply #29May 22, 2010, 08:07:41 pm
macka
  • 957
« Reply #29 on: May 22, 2010, 08:07:41 pm »
yea, but it is well made, and IMO worth the wait
