Author Topic: Franken motor!  (Read 151011 times)
Reply #210March 18, 2008, 11:02:55 am
spencebm
  • 686
Franken motor!
« Reply #210 on: March 18, 2008, 11:02:55 am »
muhahaha!
Ben Spencer
Reply #211March 18, 2008, 01:09:13 pm
Alleslowbuged
  • 270
Franken motor!
« Reply #211 on: March 18, 2008, 01:09:13 pm »
Hello,
still waiting for 200 amazing whp from a 1.6td, respect for your reached 19x whp until yet. I think the project here is "state of the art" for IDI tuning in the moment.
In germany there is a rally race rabbit, who runs with vegetable oil.
They run in the last and in this year a 1.9 tdi engine, but before used first a 1.6 and then a 1.9 idi engine for serveral years.
They try a lot to get as much power as possible, but i thing they did not reached 200hp with the idi engines. Last step idi was with gasser camshaft and therefore drill holes in the pistons for having enough space for the valve.
Anyhow, there is a nozzle expert, specialy for using vegetable oil, but also for normal diesel. I planed to build up a race 1.9 aaz rabit and speak with the nozzle guy about best nozzle design for reached something around 200 whp. He told me that test have shown, best design for the vw idi engine are DN0SD297 injectors in KCA30S36/4DS nozzles with around 175 bar POP pressure. POP pressure must increase above 155bar, due to the higher combustion pressure due to the higher boost level. I personaly think, at your boost level (approx 2.2 bar) your need even more than 175 bar POP pressure. I run my rabbit (1.6 in the moment) with 180 bar POP pressure and thing it is a little bit to high for my boost level 1,2 bar, but should fit perfect with your boost level. They nozzle guy also tells me, that they have test bigger injectors with no benefit. Big is not even nice, specialy for the nozzles everything had to be fit good together.
When i understand it correct, you have reached 193 whp with approx 1.8 bar and know reached 195 bar with 2.2 bar boost. If that is correct, you are "under fueled" in any case. Only burned fuel can make power in a idi engine, not the boost intake air. But i am sure you know that better than i do.
For me it is amazing, that you get even this power by using a Ø9mm pump. But also be sure, that the camplate has be replaced. For my project i will used a camplate from a AFN DI engine with 3,4 mm lift.
Also the pump has to be mod at the fly weights and/or the regulator spring. I will also mod the "timing change" piston lift for reached speed above 5400 rpm, stock upper limit.
Came back to the nozzles, in my knowledge the dual spring nozzles also only for reduce burning noise not for make more power. Personaly i think it is a poor design for our goals. The mention injectors also fine for cold start, even if you have reduce the compressing level.
Best Regards and good luck for 2xx whp, i am still impressed for knowing even it is possible with a 1.6 engine.
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #212March 18, 2008, 01:39:55 pm
burnt_servo
  • 278
Franken motor!
« Reply #212 on: March 18, 2008, 01:39:55 pm »
935racer ;
how much fuel presure are you running into your ip ?
 i'm assuming your using a lift pump of sorts .
have you thought about boosting the fuel presure into the ip  to help fuel the engine better when it's wound out ?
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #213March 18, 2008, 04:28:33 pm
Benjamin
  • 485
Franken motor!
« Reply #213 on: March 18, 2008, 04:28:33 pm »
Quote from: "burnt_servo"
935racer ;
Internal feul pressure will control the dynamic timing advance, so this should be +-stock, so you may not take a high pressure liftpump.
Greetz, Benjamin
Must make +250hp
Reply #214March 18, 2008, 05:29:21 pm
spencebm
  • 686
Franken motor!
« Reply #214 on: March 18, 2008, 05:29:21 pm »
where is the torque?  i would have thought that this thing would have made more torque
Ben Spencer
Reply #215March 18, 2008, 06:49:07 pm
subsonic
  • 1836
Franken motor!
« Reply #215 on: March 18, 2008, 06:49:07 pm »
Quote from: "spencebm"
It's set up to come on hard in the upper rpm range. 4000 up to redline.
Reply #216March 18, 2008, 08:52:32 pm
subsonic
  • 1836
Franken motor!
« Reply #216 on: March 18, 2008, 08:52:32 pm »
What do you think the effect of the 2 stage injection had, or has on timing?
Reply #217March 18, 2008, 09:20:32 pm
Franken motor!
« Reply #217 on: March 18, 2008, 09:20:32 pm »
Quote from: "libbybapa"
I would think that with the change to higher flowing nozzles, you were pumping more fuel into the engine and out of the pump.  That increased pumping out of the pump lowered the internal pressure and retarded the pump timing.  A little  tap, tap on the pressure regulator and 200+ HP is yours.   :D
Andrew
So what's the OE pump setting and what would you think it needs to be at?
Reply #218March 19, 2008, 02:35:17 am
Benjamin
  • 485
Franken motor!
« Reply #218 on: March 19, 2008, 02:35:17 am »
43.5 Psi at 1000 engine RPMs-75.4 psi at 2,000 RPMs
With regard to what it needs to be, I don't know.  Those specs above would be a standard pump without load.  I don't know how significant the crease in pressure would be with higher flowing injectors.  I am just making what I think is a good guess.  I'd give it a little tap and check to see what happens.    :wink:
Andrew
thats intrested libbybapa, alltough, i dont know if this is right, or not right, sidce i dont understand how the pressure regulator works.
about the right specs, i know the numbers are stated by hanger, but its unique for every pump, the right numbers you can find in the program from bosch tintin have.
Greetz, Benjamin
Must make +250hp
Reply #219March 19, 2008, 07:04:53 am
Tintin
  • 1279
Franken motor!
« Reply #219 on: March 19, 2008, 07:04:53 am »
Woaw!! It's really impressive  :wink:
But why you do not use a smaller turbo or big VNT one, I think you can past the 200HP in the more efficient 3500-4500 engine rpm range?
Andrew, the primary pump have enough flow to maintain the pressure inside the pump even with high IQ, It's more the fact that when you ask more fueling from the pump, the effort on the plunger is greater and the force counter act on the timing system and reduce or limit the timing.
Reply #220March 19, 2008, 07:25:40 am
Franken motor!
« Reply #220 on: March 19, 2008, 07:25:40 am »
But I would think the 2 stage injectors with their higher secondary pressure would prolong injection slightly. Probably not the best thing for high rpm.
Reply #221March 19, 2008, 07:55:17 am
Tintin
  • 1279
Franken motor!
« Reply #221 on: March 19, 2008, 07:55:17 am »
Yes, if you put bigger nozzle on stock IDI 1.6 or 1.9, you can ear the engine more noisy.
Higher breaking pressure have the same counter force effect on the timing, but It's minimal.
Reply #222March 19, 2008, 08:24:11 am
Franken motor!
« Reply #222 on: March 19, 2008, 08:24:11 am »
The two-stagers, from the factory, are set to break at 150 bar... a bit lower actually than the 1.6 style.
Evidently there's a small break (so-called "pre-burn") before that but it wasn't very evident on the injectors I poptested... however, she's wide open at 150 bar for sure.
Reply #223March 19, 2008, 10:30:43 am
saurkraut
  • 904
Franken motor!
« Reply #223 on: March 19, 2008, 10:30:43 am »
Quote from: "Alleslowbuged"
Hello,
Is there a rule of thumb for boost versus pop pressure.  If 155 bar is for stock boost, what pop pressure would be appropriate for 1.8 bar boost?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #224March 19, 2008, 01:04:27 pm
Alleslowbuged
  • 270
Franken motor!
« Reply #224 on: March 19, 2008, 01:04:27 pm »
Hello,
just to came back to the dual spring nozzles, by keeping in mind which time we have at 6000rpm to inject and burn the fuel, for produce power from the burning and not only burn the turbo, in my mind the dual spring injectors are not the one we wand.  (time compl. approx 0,005s, burn delay approx 0,001s )
@ TinTin,
i am sure that there is no possibility to get 200hp from a 1.6 idi engine at lower speed than 5500rpm. Even it were possible, the mechanical stress will increase and reduce reliable of the power train.
@saurkraut
there is no rule to calculate it easy.
I have make a little design program for idi engine with excel, where i can calculate the combustion pressure durin the injection.
At stock and 5500rpm with 0.8 bar boost, it will be approx 120 bar.
At 6000 rpm with 1.8 bar boost and good intercooling, it will be approx 183 bar. So to have the same pressure drop over the injector, the pop pressure should be adjusted to (155+63) approx 220bar. But for staying able to inject the neccesary amount of fuel, i think the 220bar will be to high, so in my feeling approx 180 bar pop pressure should be a good value.
Best Regards
BMW E28 524 TD
