Author Topic: who lowered their jetta?  (Read 8682 times)
May 26, 2006, 01:40:28 pm
superman293
  • 93
« on: May 26, 2006, 01:40:28 pm »
Hey there, i was thinking about lowering my 2000TDI but i dont want to give up any ride comfort, any body have experince here? i was thinking 1.5 or 1.8 inches,
thanks
Reply #1June 24, 2006, 11:12:37 pm
92A2VWJTD
« Reply #1 on: June 24, 2006, 11:12:37 pm »
I just installed a 30-40 FK Cupkit on my 1992 TD Jetta.
Stock:
30-40 FK Cupkit:
The ride is tight, rattle free, flat cornering, a little bumpy, a little bit harsher than stock on square edges, but not bone jarring by any stretch. Well worth the switch. Install is straight forward. Recommended.
Reply #2July 04, 2006, 07:42:04 am
mainer
  • 126
« Reply #2 on: July 04, 2006, 07:42:04 am »
I just grabbed H&R spring for my a1 gasser, dont have em in yet. My brother lowered his 97 A4, what a difference in ride. the thing will corner with no body roll.
If you lower the jetta I highly recamend a steel skid plate covering the oil pan and anything of any importance under there.
Coop
_________________
Knee Problems Forum
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #3July 20, 2006, 08:42:29 am
Laurentian
« Reply #3 on: July 20, 2006, 08:42:29 am »
I just lowered my A2 Jetta, looks great but decision to to this was mostly because I was still on original springs at 500,000 km's and didn't like
the body roll around corners.
Got some FK 35/40 sport springs nearly new on vwvortex half price. They are very stiff in front and medium in rear. Like poster above said harsh on square edge but very OK otherwise. Was set-up with KYB GR2 gas shocks on all corners and they are a good match for the rear but
underdampened for front. I tend to bounce a bit too much to my liking.   ( like a Case backhoe on a country road )
Most people warned me but I didn't listen, kind of wishful thinking that it would be OK because I payed 250.00 tax in for the four.
I'll be going Bilstein in front when I can afford.
BTW : Personaly I wouldn't go any lower for a daily driver :!:
Reply #4July 20, 2006, 04:17:08 pm
sethyboy85
  • 284
« Reply #4 on: July 20, 2006, 04:17:08 pm »
I will have to snag some pictures (washed or unwashed) and show you how low I went with 1.5" drop springs... I went with a 5way adjustable tokico struts up front (very nice) can make it feel cadilac smooth or no balls left hard up front, back TurboBoge they are doing okay.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #5July 20, 2006, 08:33:58 pm
akrallysport
« Reply #5 on: July 20, 2006, 08:33:58 pm »
I have a mk3 Jetta and just dropped it with Neuspeed Sport springs and Bilstein Sports struts/shocks. It's supposed to be a 1.3" drop all around on the mk3 and the lowest I'd go on a daily.
Pics tmw morning.
Reply #6July 21, 2006, 07:38:54 am
Laurentian
« Reply #6 on: July 21, 2006, 07:38:54 am »
I'll try and set-up some pics also!
BTW just hade the rear axle bushings and front ball joints replaced.
Much better handeling now, not nearly as bouncy.
It seems as if the shocks are breaking in or the gas / oil in the shocks are leveling / migrating to proper order?
Does this make sense, your experience?
The mechanic confirmed that he did cycle the rods before installation but I wonder. Anyhow he mentioned that the fluids do level out with use.
The reason I bring this up is that on the KYB install sheet they mention this as a warranty void item if not done.
Hugh
Reply #7July 25, 2006, 09:16:30 am
bustedfoxwagen
  • 31
    • http://www.wagenwerks.net
« Reply #7 on: July 25, 2006, 09:16:30 am »
ebay speacial add on coilovers
got it pretty low
92 eco diesel jetta
Reply #8July 26, 2006, 05:56:20 am
Laurentian
« Reply #8 on: July 26, 2006, 05:56:20 am »
I have the FK sport springs 35/40 drop.
What is the FK cup-kit above?
Does that consist of the saucers / seats that drop the ride height?
BTW Am happy with the spring rate of these springs, they may be on
the soft side as far as sport springs are concerned but fit my needs for daily driver. I would like more damping if front however and may
go the Tokico adjustable route in the futur.
Hugh
OK, did the research, cup kit is the FK struts and coils together.
Thought it may just have been the dishes.
Anyhow I noticed some surface rust / peeling undercoating where the
rear spring mounts are in the upper fender wells.
Should I blast, prime and reseal with undercoating, any suggestions?
http://www.vwquebec.ca/forum/album_pic.php?pic_id=1194http://
Reply #9July 30, 2006, 10:36:20 am
VolkSport
  • 11
« Reply #9 on: July 30, 2006, 10:36:20 am »
My '85 Wolfs GL TD with FK 85/70 lowering springs / struts
'60 Beetle
'85 Jetta TD
Dune Buggy
Reply #10January 18, 2007, 07:59:37 am
« Reply #10 on: January 18, 2007, 07:59:37 am »
Quote from: bustedfoxwagen
got it pretty low
I'm gonna dredge up an old thread here,  How do you like the ride of those coil overs bustedfoxwagen?
