Diesel & Megsaquirt
Topic: Diesel & Megsaquirt (Read 4831 times)
August 11, 2015, 09:09:03 pm
JJD
Newbie
Diesel & Megsaquirt
August 11, 2015, 09:09:03 pm »
Can you use a Megasquirt on a Diesel or Tdi ...
How can i go about it ?? thank you!!
August 11, 2015, 09:57:10 pm
RunninWild
Re: Diesel & Megsaquirt
August 11, 2015, 09:57:10 pm »
You probably could with a tdi but IDI engines are all mechanical and dont have computer controls.
August 12, 2015, 04:23:02 am
August 12, 2015, 04:23:02 am »
the answer is definitely NO unless they make a diesel specific one.
August 12, 2015, 11:47:24 am
August 12, 2015, 11:47:24 am »
Megasquirt could probably be adapted to a VE pump - I mean there's a standalone arduino-based controller for the VE already. Really there's no reason why not, it'd just take a lot of engineering and understanding of how things work. A common rail diesel isn't that different from a gasoline one as far as the injection control system is concerned - more precise timing and a much shorter injection duration...
August 12, 2015, 08:07:22 pm
JJD
Newbie
August 12, 2015, 08:07:22 pm »
Would any other stand alone work?? Cause ..i would like to fit a diesel in an aircooled beetle...to travel around in the summer!!
What would be the best way to go about it???
Thanks Guys!!
August 12, 2015, 09:55:10 pm
August 12, 2015, 09:55:10 pm »
The latest MS has CANbus control for HE351VE, which would put it similar price and way more versatile than any other controller I've seen, for my Dodge at least.
I have 2 of them, but I don't know if the 2.5 IDI in my Volvo would spool such a beast. I did look at it enough to determine that the hood could be made to close.
August 13, 2015, 04:34:29 am
August 13, 2015, 04:34:29 am »
i really don't see how it would be possible to use megasquirt on a diesel since the fuel delivery is completely different. if you are putting a diesel in a beetle just use a mechanical pump or do an electronic swap, it would actually be less work to go electronic than use megasquirt if it even would work.
August 13, 2015, 08:56:42 am
turboedbug
August 13, 2015, 08:56:42 am »
It wouldn't be worth the time in my opinion. Just do a mechanical pump and it would save a lot of headaches. Or do what I did and install a turbocharged ej20 Subaru and crank up the boost and beat 99.99% of the cars u see on the road hahahahah
August 19, 2015, 12:33:42 pm
Jetmugg
August 19, 2015, 12:33:42 pm »
If you want to put a diesel in an air-cooled Beetle, simplest way is to get an adapter plate and run a mechanical IDI diesel. No computers, no muss, no fuss.
Steve.
Diesel & Megsaquirt
