Author Topic: Resealed IP not pumping any fuel?  (Read 38526 times)
Reply #120February 01, 2014, 08:49:50 pm
Re: Resealed IP not pumping any fuel?
« Reply #120 on: February 01, 2014, 08:49:50 pm »
The highest point in Michigan is Mount Arvon, at 1,979 feet above sea level.  Only 3% of the states population live in the Upper Penninsula.  So driving is pretty easy until you find that most folks really never learned the difference between a car, snowmobile or a boat.  They drive them all the same.
https://www.google.com/maps/preview/place/Mt+Arvon/@46.7238386,-88.2059201,21624m/data=!3m1!1e3!4m2!3m1!1s0x4d5103bf6e72ca33:0x4924c1544510c1f8
Reply #121February 01, 2014, 09:17:07 pm
jhax
  • 324
Re:
« Reply #121 on: February 01, 2014, 09:17:07 pm »
Funny I am snowboarding tomorrow at 10.5k feet and that is one of the short ones! http://en.m.wikipedia.org/wiki/Mount_Werner
Sent from my DROID SPYDER using Tapatalk
Reply #122February 02, 2014, 04:15:22 pm
jhax
  • 324
Re:
« Reply #122 on: February 02, 2014, 04:15:22 pm »
So w still noticing a slight lack of power. I am running it pretty advanced. My IP is dead nuts on the mark at tdc. If I want to move it a tooth off, which way ccw or cw should I move the sprocket by one tooth?
Reply #123February 02, 2014, 04:33:19 pm
« Reply #123 on: February 02, 2014, 04:33:19 pm »
Getting any dark soot? If not, the full load might need another twist.
Reply #124February 02, 2014, 05:06:43 pm
jhax
  • 324
Re:
« Reply #124 on: February 02, 2014, 05:06:43 pm »
No coal rolling whatsoever.  I cant adjust my max fuel screw any more due to damaged threads from the OEM metal collar that was spot welded into it.
Reply #125February 02, 2014, 05:16:34 pm
« Reply #125 on: February 02, 2014, 05:16:34 pm »
Got a spare IP that you can swap out the fuel screw?  Who would do that to an adjustable part?
Spot weld the accelerator too why you are at it.
Reply #126February 02, 2014, 05:35:19 pm
« Reply #126 on: February 02, 2014, 05:35:19 pm »
I'd try to clean up them threads. A die might not do it, the weld will be hard... I'd use diamond files, it shouldn't take long.
http://www.harborfreight.com/10-piece-diamond-grit-needle-file-set-69876.html
Reply #127February 02, 2014, 05:49:48 pm
jhax
  • 324
Re:
« Reply #127 on: February 02, 2014, 05:49:48 pm »
Orcoaster  I like the way you think. Completely forgot about my spare IP. The thing is though, before I did the reseal if I had max fuel in as Mich as I do now it would roll coal like no tomorrow. I took the collar off after I put the newly sealed pump in.
Reply #128February 02, 2014, 05:52:04 pm
jhax
  • 324
Re:
« Reply #128 on: February 02, 2014, 05:52:04 pm »
My extra screw has a collar on it as well.
Reply #129February 02, 2014, 08:51:33 pm
« Reply #129 on: February 02, 2014, 08:51:33 pm »
All fuel screws have some sort of limiter on them.  All of mine are just pressed tightly on.  You can see the mark.  But if you take the screw out and secure it well in a vise you can get the adjustment to move or even become a null thing.  I had one restrictor that I pinched 90 degrees to the mark and it more or less let go.  I could bottom out that screw if chose to.
Collars are aluminum are they not?  Softer than the screw it self so can't you just hold the collar and thread it by turning the screw inside it?  I can see if it was welded that wouldn't happen.  But surely someone is not happily running around CO with a MIG causing all this havic?
Reply #130February 02, 2014, 09:11:32 pm
« Reply #130 on: February 02, 2014, 09:11:32 pm »
all of mine have been steel resistance welded to the screw.  pry the seam open a tiny bit, and drill or grind the weld, instant adjustable stopper.
Reply #131February 03, 2014, 05:55:09 am
« Reply #131 on: February 03, 2014, 05:55:09 am »
M8x1.00  I've run a tap over many of them.
Reply #132February 03, 2014, 12:42:15 pm
jhax
  • 324
Re:
« Reply #132 on: February 03, 2014, 12:42:15 pm »
I took the screw out and the issue is that the collar that holds the o-ring in place is the thing that is preventing the screw from being threaded in more. Not the threads themselves.
Reply #133February 03, 2014, 12:44:55 pm
jhax
  • 324
Re:
« Reply #133 on: February 03, 2014, 12:44:55 pm »
So the lever is pushed in as far as it can go.
Reply #134February 03, 2014, 02:25:27 pm
« Reply #134 on: February 03, 2014, 02:25:27 pm »
If that is the case than you STILL have the accelerator lever to shaft alignment incorrect.  One click the opposite of what I described before.  When the revs were hanging before, had you run out of idle adjustment?  Was the lever rotated all the way back so that it was hitting the case at idle?
