Author Topic: Resealed IP not pumping any fuel?  (Read 40633 times)
Reply #105January 30, 2014, 12:15:29 pm
Re: Resealed IP not pumping any fuel?
« Reply #105 on: January 30, 2014, 12:15:29 pm »
You get the props for perseverance, dude.
Reply #106January 30, 2014, 12:23:11 pm
Re:
« Reply #106 on: January 30, 2014, 12:23:11 pm »
Well just as I thought everything is dead on mark wise. I used the dial indicator and got it as close to 0.90 +- .05 as I could and tightened everything up. Still hangs in the higher revs and still feels sluggish in first. I backed off fuel screw as much as I could and adjusted idle accordingly. I also cracked my injectors and heard idle drop at each one. There is a significant amount of white smoke too which tells me it still may be out of time.
Sent from my DROID SPYDER using Tapatalk
Reread my last post.
Reply #107January 30, 2014, 03:31:24 pm
jhax
  • 328
« Reply #107 on: January 30, 2014, 03:31:24 pm »
Libby, that ended up being the issue. Fiddled around with the governor shaft and throttle orientation and found the sweet spot. Advanced it just a smidgen without the indicator. My car runs and it seems to run well. Much less smoke, most of it coming from the crank case dump tube to the ground I made for it. I backed it up and forwarded it several times in my shop and drove a little on the driveway. I can't do much extensive driving due to the lack of snow tires and bountiful amounts of snow falling, but what driving I did do it felt like it's old self again. No hanging idle and it revs quick. I'll wait until we can plow the driveway to drive it. And yes I am a persistent person and it pays off. Thanks again for everyone's help. Definitely one of my favorite aspects of owning a VW is the help we as a community give each other.
Reply #108January 30, 2014, 03:54:48 pm
jhax
  • 328
« Reply #108 on: January 30, 2014, 03:54:48 pm »
« Last Edit: January 30, 2014, 03:59:16 pm by jhax »
Reply #109January 30, 2014, 10:00:33 pm
« Reply #109 on: January 30, 2014, 10:00:33 pm »
NICE 4 Dr there fella.  Glad you got it back up and going.  As you have learned there are more adjustments on this thing than meet the eye.  Some are more forgiving than others.  That Accel lever seems to be the worst of the bunch.  Libby tells how to fix it the best so I defer to him when that discussion comes about.  I think the hardest thing for us to do it try and figure this out long distance without the hands on, eye on, ear on thing we as mechanics need to have to get to the root of the problem.
Good luck with the final tune.
Reply #110January 30, 2014, 10:36:28 pm
jhax
  • 328
« Reply #110 on: January 30, 2014, 10:36:28 pm »
ORcoaster, I know what you mean. It can be very hard to explain certain things in detail, I find TylerDurden's typed noises work out well...sometimes haha. Thanks for the encouragement. Hopefully this thread can help others out through similar processes. Now if only it would stop snowing and the roads would get cleared up so I can go for a drive..BAH I'm going to go crazy waiting.
Justin
Reply #111January 31, 2014, 04:51:57 pm
« Reply #111 on: January 31, 2014, 04:51:57 pm »
In that big ole shop you don't have a good set of jack stands to run it through the gears?   I can't believe that.   Clackity Clickity.
Varoommmmmmmmmmmmmm
Reply #112January 31, 2014, 07:06:06 pm
jhax
  • 328
« Reply #112 on: January 31, 2014, 07:06:06 pm »
I have two sets of jack stands. But shifting through the gears with no resistance is different than shifting through the gears under load.
Reply #113January 31, 2014, 07:25:45 pm
« Reply #113 on: January 31, 2014, 07:25:45 pm »
Got snow, got tractor, got resistance.  Pile it up and let the bunny push against it.  About the time you hit third you should break through so best be heading out the shop doors.
Reply #114January 31, 2014, 07:35:51 pm
jhax
  • 328
« Reply #114 on: January 31, 2014, 07:35:51 pm »
Haha, I used the tractor to plow the driveway this morning so I could drive up an down with the golf. It passed the starting on an uphill test. Got it up to third but couldnt go faster without spinning the tires on snow pack.
Reply #115January 31, 2014, 08:23:19 pm
« Reply #115 on: January 31, 2014, 08:23:19 pm »
I ran a good set of snowtires on mine the last couple of years and never had a tire spin issue.  These VW's are notorious for being good handlers on snow and ice.  Long before others started in on the front wheel drive production.
Reply #116January 31, 2014, 09:10:03 pm
jhax
  • 328
Re:
« Reply #116 on: January 31, 2014, 09:10:03 pm »
Well as low as my car is I can't fit anything too low profile without paying a lot of money. Plus there is snow and then there is steamboat snow. Whole different animal.
Reply #117February 01, 2014, 07:27:04 pm
« Reply #117 on: February 01, 2014, 07:27:04 pm »
I didn't notice it was lowered.  That would make a big difference on studded tires that were just a tad higher.  Brrr, Brrr there goes the wheel well.  I actually lifted mine because of the snows.  I put 14 inch snowflakes on and the 185 70R 14's are taller than the summer scooters.  155 80R 13.
So Steamboat snow is more slip and slide than say Michigan snow?   That's why everyone wants to ski there.   Well if they have snow.
Reply #118February 01, 2014, 08:14:08 pm
jhax
  • 328
Re:
« Reply #118 on: February 01, 2014, 08:14:08 pm »
Yes sir, roads stay ice packed for weeks or months at a time. I'm running 205 50 R 15 all seasons with 1.5" neuspeed lowering springs and I get rubbage with these just barely though.
Reply #119February 01, 2014, 08:27:00 pm
« Reply #119 on: February 01, 2014, 08:27:00 pm »
How many thousand feet is the biggest cliff you can fall off in Michigan anyway?
