Author Topic: Resealed IP not pumping any fuel?  (Read 40621 times)
Reply #135February 03, 2014, 04:08:42 pm
jhax
  • 328
Re: Resealed IP not pumping any fuel?
« Reply #135 on: February 03, 2014, 04:08:42 pm »
I know you all like pictures so here you are...
Flywheel @ TDC
IP sprocket @ TDC (dead on)
Curious...two IP sprocket marks?
Orientation of vertical gov. screw, idle adjustment screw (relatively far in), max speed stopping screw (still has wire through the end from the factory never adjusted) and IP advancement (notice how close to hard fuel line it is).
Reply #136February 03, 2014, 04:38:31 pm
« Reply #136 on: February 03, 2014, 04:38:31 pm »
Excellent. I was hoping some pix would show up!
The screw I refer to is the one under the words "FUEL OUT", it makes contact with the lever that I assume got bent:
That screw has a stainless collar tack-welded to the threads. Pry that collar off and turn that screw a half turn and see how it goes. Repeat until power is better. The idle will be higher, but you can bring it down with the stop. When you are getting a bit of dark soot, you may be in the zone, but watch for hanging revs.
Reference:
RE advance: I'd move the IP and pulley a tooth away from the head (CW as viewed from the right fender).
That second pulley mark (rightmost) seems bogus to me...
Reply #137February 03, 2014, 04:59:53 pm
jhax
  • 328
« Reply #137 on: February 03, 2014, 04:59:53 pm »
Thanks sir, I knew you were referring to the governor screw. We took the collar off already and screwed it in as far as it would go. I was thinking of moving the IP sprocket one tooth fwd but I just wanted verification. I think the vertical governor screw i think is really just where it needs to be but if it comes to it I think I'll rotate that one click CCW (mentioning the springs ever so slightly). Is there an easy way to rotate the pump sprocket one tooth CW without going through the usual motions. I was reading somewhere on sandwiching a flat piece of cardboard in between the sprocket teeth and belt and rotating the pump. Which should I try first? Vertical screw or sprocket rotation? Also both marks are factory stamped, just to emphasize.
« Last Edit: February 03, 2014, 05:07:53 pm by jhax »
Reply #138February 03, 2014, 05:15:03 pm
« Reply #138 on: February 03, 2014, 05:15:03 pm »
Well, moving the sprocket and IP just gets you more range to advance timing if you think it will need it. If you have no white/grey smoke, your advance may be fine for now.
If the accelerator lever and shaft are dialed-in without hanging revs, I'd leave them be for now, too.
If the issue is lackluster power, I'd clean up the threads of the full-load screw, if that's what is keeping it from turning in further. If the nubbin or its related bits got bent even a fraction of a millimeter, it would dramatically affect the power.
Reply #139February 03, 2014, 05:19:47 pm
jhax
  • 328
« Reply #139 on: February 03, 2014, 05:19:47 pm »
My dad is wondering how much the pump will advance by moving it a tooth CW while keeping the pump its self (bracket bolts) tight.
Reply #140February 03, 2014, 05:28:14 pm
« Reply #140 on: February 03, 2014, 05:28:14 pm »
You ABSOLUTELY have enough idle adjustment to go one spline with the accelerator shaft to lever alignment.  When you had hanging revs why didn't you just lower the idle?
Reply #141February 03, 2014, 05:45:34 pm
jhax
  • 328
« Reply #141 on: February 03, 2014, 05:45:34 pm »
When I had hanging revs it was only in the higher revs when I blipped the throttle. Not during idle at all, idle seemed normal at the time, even low. Ill puth the enrichment screw back in (only until it just touches the lever), and tension the vertical governor shaft a spline and see what happens.
Reply #142February 03, 2014, 06:07:56 pm
« Reply #142 on: February 03, 2014, 06:07:56 pm »
I have tuned a vast number of pumps from scratch and the only time I have ever seen hanging revs at higher rpms is when the idle was too high.
Reply #143February 03, 2014, 06:23:21 pm
jhax
  • 328
Re:
« Reply #143 on: February 03, 2014, 06:23:21 pm »
That is understandable. However the only thing I changed to get rid of hanging high rpm idle was rotate the governor shaft cw releasing tension on the spring. I'll tighten the spring and put the governor in a little ways now and get back with results.
Sent from my DROID SPYDER using Tapatalk
Reply #144February 03, 2014, 07:18:57 pm
jhax
  • 328
Re:
« Reply #144 on: February 03, 2014, 07:18:57 pm »
Right it worked. Idles happy max fuel screw is roughly where it was as is idle screw. The governor screw is now on the tick mark closest to the front of the engine. The only difference is that it takes slightly longer for the revs to come back down to idle after the throttle is blipped and physically returns to the idle screw.
Reply #145February 03, 2014, 08:15:34 pm
« Reply #145 on: February 03, 2014, 08:15:34 pm »
IIRC, there are 44 teeth on the sprocket... 360/44= 8.18o cam (16.36o crank).
Reply #146February 12, 2014, 03:44:14 pm
jhax
  • 328
Re:
« Reply #146 on: February 12, 2014, 03:44:14 pm »
Finally got to drive it today and it runs like a dream. I'm loving the governor mod too.
Reply #147July 17, 2014, 04:16:22 pm
Diesel_Zuk
  • 182
« Reply #147 on: July 17, 2014, 04:16:22 pm »
Whatever ended up being the problem with this? I'm tired and tried to read through it, but can't follow. I just want to drive my jetta again.  :-[
