Author Topic: No Horn  (Read 4037 times)
May 19, 2011, 09:11:12 am
rodpaslow
  • 670
No Horn
« on: May 19, 2011, 09:11:12 am »
I've read lots of posts on horns.  Mine is not working.  The relay stopped clicking last night when I was trouble shooting.  The fuse had blown so I put a new one in and now the relay doesn't click.
Does the actual horns in the engine bay (96 golf) get power all the time, and the relay strickly grounds them to work, or does the relay suppy power? Should there be power at the horn all the time or only when the relay is on?
Is the horn button a ground system where it grounds the relay or can you check for power at the horn button as well?
Thanks
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
Reply #1May 19, 2011, 04:58:14 pm
  • 1739
Re: No Horn
« Reply #1 on: May 19, 2011, 04:58:14 pm »
IF I remember, the switch in the steering wheel grounds the relay which then sends power to the horns. If you can't hear the relay, your problem is from the relay back to the steering wheel. Most likely the relay, contact slip ring or the horn switch
Reply #2May 19, 2011, 05:54:07 pm
rabbitman
  • 2788
Re: No Horn
« Reply #2 on: May 19, 2011, 05:54:07 pm »
My horn ground was bad when I got it, fixed that and everything was good.
Reply #3May 20, 2011, 07:16:54 am
rodpaslow
  • 670
Re: No Horn
« Reply #3 on: May 20, 2011, 07:16:54 am »
I looked in my bently manual and all that was wrong was the relay #53 (usually horn relay) was in the wrong location.  Moved to the correct one, now horns work beautifully!
Reply #4May 20, 2011, 04:52:00 pm
  • 1739
Re: No Horn
« Reply #4 on: May 20, 2011, 04:52:00 pm »
I guess that's why the relay wasn't clicking !
