General Information
Troubleshooting
No Horn
Topic: No Horn (Read 4097 times)
May 19, 2011, 09:11:12 am
rodpaslow
No Horn
May 19, 2011, 09:11:12 am »
I've read lots of posts on horns. Mine is not working. The relay stopped clicking last night when I was trouble shooting. The fuse had blown so I put a new one in and now the relay doesn't click.
Does the actual horns in the engine bay (96 golf) get power all the time, and the relay strickly grounds them to work, or does the relay suppy power? Should there be power at the horn all the time or only when the relay is on?
Is the horn button a ground system where it grounds the relay or can you check for power at the horn button as well?
Thanks
May 19, 2011, 04:58:14 pm
Re: No Horn
May 19, 2011, 04:58:14 pm »
IF I remember, the switch in the steering wheel grounds the relay which then sends power to the horns. If you can't hear the relay, your problem is from the relay back to the steering wheel. Most likely the relay, contact slip ring or the horn switch
May 19, 2011, 05:54:07 pm
Re: No Horn
May 19, 2011, 05:54:07 pm »
My horn ground was bad when I got it, fixed that and everything was good.
May 20, 2011, 07:16:54 am
rodpaslow
Re: No Horn
May 20, 2011, 07:16:54 am »
I looked in my bently manual and all that was wrong was the relay #53 (usually horn relay) was in the wrong location. Moved to the correct one, now horns work beautifully!
May 20, 2011, 04:52:00 pm
Re: No Horn
May 20, 2011, 04:52:00 pm »
I guess that's why the relay wasn't clicking !
General Information
Troubleshooting
No Horn
