Author Topic: Heater core..  (Read 11028 times)
May 16, 2011, 07:59:31 pm
Heater core..
« on: May 16, 2011, 07:59:31 pm »
for any of you that might be blessed with the great misfortune of changing heater cores in a mk2, just a reminder, it is a beeeeeeeeotch!
Reply #1May 16, 2011, 08:09:16 pm
Dakotakid
  • 1240
Re: Heater core..
« Reply #1 on: May 16, 2011, 08:09:16 pm »
I've currently got 3 Mk. II's (with air) which need this done......why don't you get yer butt oooot here and do them, EH??? 8)
Reply #2May 16, 2011, 08:30:34 pm
Re: Heater core..
« Reply #2 on: May 16, 2011, 08:30:34 pm »
EH??? 8)
Can an American use this term?  ;D I think we back-bacon eaters have it coined lol.
Reply #3May 17, 2011, 02:58:30 am
bvolks73
  • 183
Re: Heater core..
« Reply #3 on: May 17, 2011, 02:58:30 am »
I just did the heater core in my 95 Golf and I'd rather change one in a MKII any day.
« Last Edit: May 17, 2011, 05:25:23 pm by bvolks73 »
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #4May 17, 2011, 08:00:21 am
Re: Heater core..
« Reply #4 on: May 17, 2011, 08:00:21 am »
oh wow, great.. thanks for that piece of info, next on my plate is a heater core replacement on a 95 Jetta..  :'(
on a side note, i found out that non-a/c cars do NOT have the same heater fan as an a/c car.. they have the same heater box and core, but the fan is DIFFERENT. the motor is mounted vertically, instead of horizontally. and it has a foam guard on the bottom of it that is great at holding water. the rust ring around my old fan motor was half way up the actual motor. not a chance it still works.
i like my car because its different (bare bones CIS, manual everything, no options) but i also hate how hard it is to find certain parts for it. it had some sort of dinky little radiator in it when i got it, and appearently it leaked when under pressure, so i swapped that out for an a/c rad, it was about 6 INCHES WIDER!!
ive only seen a handful of mk2s that are as bare bones as my 86 golf.. the first time i popped the hood, i about shat, you could see light all around the engine. SOO MUCH room under the hood. not having an a/c pump really makes things simple.
Reply #5May 17, 2011, 03:35:03 pm
  • 1739
Re: Heater core..
« Reply #5 on: May 17, 2011, 03:35:03 pm »
??? sorry but you must have done it some kind of long way. On a mk2 diesel NA and no a/c can be done in an hour and a half, 2hours max for any one. Mk3 's are much worse, the whole dash and knee bar have to come out. Mk 1's don't take too long if you cut the end of the box out, but are a pain as you have to stick your head under there for the whole time. late 70 big fords were the best- remove the front right wheel, cut out a hole in the wheel well !
Reply #6May 17, 2011, 05:51:32 pm
macka
  • 957
Re: Heater core..
« Reply #6 on: May 17, 2011, 05:51:32 pm »
caveman,
   by far the easiest heater core to change is a 68 Fargo pick up.
Quote from: Vincent Walden
I do know that I drive torque,  while listening to my friends prattle on about horsepower.
Reply #7May 17, 2011, 07:21:21 pm
Re: Heater core..
« Reply #7 on: May 17, 2011, 07:21:21 pm »
it wasnt super time consuming. i just had to do everything.. core, hoses, blend doors, heater motor.. and there was the time spent pulling parts off cars out back.. so the actual heater core replacement wasnt THAT bad.
Reply #8May 17, 2011, 07:28:50 pm
Re: Heater core..
« Reply #8 on: May 17, 2011, 07:28:50 pm »
Sawsall time!   And looking at that dash gave me a great idea for sound deadening that I really need to do.  Foam, spray on type.  Anyone agree?
Reply #9May 17, 2011, 09:15:00 pm
  • 1739
Re: Heater core..
« Reply #9 on: May 17, 2011, 09:15:00 pm »
caveman,
I mentioned it for the hilarity factor,
it's the way the factory designed it
Reply #10May 18, 2011, 09:05:26 am
Re: Heater core..
« Reply #10 on: May 18, 2011, 09:05:26 am »
i know you dont get lucky on a mk2 or mk3, you gotta pull the dash. you cant get to the heater core any other way, unless you cut a hole in the rain tran, and firewall possibly.. lol.
Reply #11May 18, 2011, 09:32:58 am
clbanman
  • 705
    Cambridge, Ontario
Re: Heater core..
« Reply #11 on: May 18, 2011, 09:32:58 am »
caveman,
I did a heater core on one of my father's cars (if memory serves me correctly - a 79 Olds 98) that involved taking the two heater hoses off the core at the firewall, removing one screw and a cover plate, and then pulling out the heater core.   Took all of about 10 minutes start to finish.   Best design ever for heater core.
Calvin
91 VW Golf 1.6NA 5spd
Reply #12May 18, 2011, 09:40:04 am
Re: Heater core..
« Reply #12 on: May 18, 2011, 09:40:04 am »
72 Chev pickup heater cores were external of the cab. i believe all you had to do was pull the fan housing off, and there it was.. they were one of the easier ones to replace too..
Reply #13May 18, 2011, 11:30:02 am
rabbitman
  • 2788
Re: Heater core..
« Reply #13 on: May 18, 2011, 11:30:02 am »
I just did my mk2 heater core w/o air and it was waaay simpler than I thought it would be. I did not have to remove the dash.
Reply #14May 18, 2011, 11:48:18 am
Re: Heater core..
« Reply #14 on: May 18, 2011, 11:48:18 am »
how on earth did you get the heater box out from under the dash without pulling the dash? i dont see how it can be done without atleast loosening the dash..
