Author Topic: Heater core..  (Read 11189 times)
Reply #15May 18, 2011, 04:47:38 pm
bvolks73
  • 183
Re: Heater core..
« Reply #15 on: May 18, 2011, 04:47:38 pm »
I've never had to pull the dash to change one in a MKII and I've changed a half a dozen or so.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #16May 18, 2011, 05:26:07 pm
  • 1739
Re: Heater core..
« Reply #16 on: May 18, 2011, 05:26:07 pm »
Sawsall time!   And looking at that dash gave me a great idea for sound deadening that I really need to do.  Foam, spray on type.  Anyone agree?
i know you dont get lucky on a mk2 or mk3, you gotta pull the dash. you cant get to the heater core any other way, unless you cut a hole in the rain tran, and firewall possibly.. lol.
Mk2's don't need the dash to be pulled. The box can be removed by removing the center console etc. Like i said, a NA diesel without AC can be done in a little over an hour
Reply #17May 19, 2011, 10:05:05 am
Re: Heater core..
« Reply #17 on: May 19, 2011, 10:05:05 am »
i must be retarded then, because i couldnt do it without pulling the dash.. i left the fan and the fan tube (dunno what its called, goes in place of the a/c box) and i had to pull the bottom edge out first, then tilt it out from under my dash.. those stupid clips holding the heater box to the fan tube are RETARDED too..
the part that bolts on the front of the heater box, that controls the 4 dash vents, how would you go about getting the box out with that piece still there?
idk, maybe i did it the hard way, but i fixed alot more than just the heater core.. i did find my ANT FARM in the car. would have never found it had i not pulled the dash.. so, im still happy i pulled the dash partially out..
