View full version: General
  1. Good Mercedes Diesel forum?
  2. Air in fuel line (Pics)
  3. Stickers for Giles
  4. Mk1 1.6D jetta waterpump help
  5. TD Golf Auto-X vids.
  6. Lucas Replacment Harness
  7. Lost an AC Compressor Adjuster Bolt
  8. golf van ...
  9. messed up my Radio Code
  10. How do I hook up the tach?
  11. oil pan compatibility
  12. Drove a Giles injection pump on a N/A diesel ** hp numbers**
  13. site back up
  14. this pissed me off
  15. Finally vw is selling an L1
  16. A turbo thought for big power IDI/TDI's
  17. Can a 1.6L be made into a 1.9 by swapping Rods?
  18. Oldest GTD Driver in the world needs help ;o)
  19. Thinner grade oil = huge blowby I think
  20. Compressor map for AAZ's T2
  21. PROBLEMS WITH OLDER SOLID LIFTER DIESELS
  22. how do you insert an image into a post /
  23. Plug in motorcycle
  24. Diferent color Boost Pin Springs?
  25. Mk2 trans in a mk3??
  26. Don't click if you get ill easily. Worse than porn spam.....
  27. Putting my girlfriend to work.
  28. Cooking oil for Fuel?
  29. diesel additive question
  30. Goodbye @#^%* Exh. C-clamps!
  31. Need a little help, Maine / NH / Mass area.
  32. Gov NR mod questions
  33. Brake booster pump dealy-mo
  34. B100
  35. Off-the-shelf options for AAZ downpipes ??
  36. Another bumb Question.
  37. Just a quick question.
  38. Please pray for a fellow dubber!!
  39. Aftermarket speedometer
  40. Finally got my car on the road... almost
  41. Cooling system upgrade. Everyone should have a look here.
  42. Any one done gas to diesel?
  43. 1993 Passat TD alternator question.
  44. Annoying timing cover rattle
  45. can someon ban harriettvanders for spamming please
  46. Dyno day
  47. cloth return line routing
  48. Buying TDI Beetle w/top end issue... advice please
  49. vw turbo diesel starting question
  50. dieselrules
