Author Topic: Lost an AC Compressor Adjuster Bolt  (Read 5317 times)
May 21, 2008, 10:15:21 pm
Op-Ivy
  • 513
« on: May 21, 2008, 10:15:21 pm »
I found out yesterday that one of the adjusting bolts for my AC compressor has rattled it's way out.
At the local junkyard, diesel jettas are not terribly plentiful. However there are tons of gas ones. So I was wondering...
Does a gasser has the same identical bolt that I could go and snatch?
Thanks, Matt
Reply #1May 22, 2008, 05:49:56 am
smoken u
  • 231
« Reply #1 on: May 22, 2008, 05:49:56 am »
yes it does,
I had the same problem only all the bolts fell out, and my AC compressor was only held on by the belt ( still drove for about a month :shock: )
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #2May 22, 2008, 06:18:07 am
Op-Ivy
  • 513
« Reply #2 on: May 22, 2008, 06:18:07 am »
What?!? Wow!
Good news about the bolt though! Thanks smoken!
Reply #3May 22, 2008, 06:48:52 am
DCC
  • 184
« Reply #3 on: May 22, 2008, 06:48:52 am »
Quote from: "smoken u"
yes it does,
Those bolts tend to fall out. That same thing happened to a friend's mk2 gasser: it was held in place by.. ehmm.. magic.  :lol:
The bolts are almost the same (M8, and M10 bolts and nuts), the adjusting bolt is exactly the same, but has a different reference number (one for diesels, one for gassers).
Here you go. The first one is diesel, the second is gasser.
Reply #4May 22, 2008, 07:03:12 am
« Reply #4 on: May 22, 2008, 07:03:12 am »
When I was rebuilding my engine I used my Dremel and cut a "X" in the end of the bolt and spread it apart a tad with a small screw driver to prevent it from falling out..
Still there today. Of course I only have about 5000 miles on it.
