General Information
General
How do I hook up the tach?
Topic: How do I hook up the tach? (Read 5262 times)
May 18, 2008, 07:51:37 am
spencebm
May 18, 2008, 07:51:37 am »
I have come across a tachometer and need to swap it in my car. I have done some searching and found little about actually running a wire from the W terminal to the tach in the cluster. What kind of pick up wire should I run and how does it fit into the cluster? Any help would be great! Thanks!
Ben Spencer
May 18, 2008, 08:48:58 am
gigaz2
May 18, 2008, 08:48:58 am »
any kind of insulated wire, its just a signal, no current.
your tachometer is a diesel one right? aftermarket stuff is 99% gas, and they don't work with W signal.
even so you can always improvise an pickup, optical or Hall effect.
May 18, 2008, 12:54:22 pm
May 18, 2008, 12:54:22 pm »
Here's the chart you need to determine what cluster pin goes to the W terminal:
http://www.xjamiex.com/mk2resource/electrical/CE2cluster.html
And yeah... it needs to be a diesel tach (only goes to 5.5K). If it goes to 7K it's a gasser tach and won't work directly... lots and lots of data here and at
www.vwdieselparts.com
on options.
May 19, 2008, 06:16:43 am
spencebm
May 19, 2008, 06:16:43 am »
thanks for the help
Ben Spencer
General Information
General
