Author Topic: Cooling system upgrade. Everyone should have a look here.  (Read 10093 times)
July 31, 2004, 07:52:08 pm
Dr. Diesel
  • 1341
« on: July 31, 2004, 07:52:08 pm »
Rummaging around my stuff, I found a forgotten-from-gas-rabbit-days half case of coolant. Not just any coolant. This stuff is made by Evans cooling, and they call it NPG. Non-aqueous Propylene Glycol.  They sell it alone or with kits for common detroit iron engines to create reverse flow cooling systems. All pretty fancy. The basic idea is that this coolant doesn't use water, and simply picks up heat way better. For VW engines, they told me don't bother with the reverse flow idea (from the rad outlet to the cylinder head rather then up through the block. Keeps the combustion chambers cooler and allows more detonation resistance) just run it in the factory system as is, or with no pressure.
Seeing as I had everything in pieces, I decided to use it when it was all back together. This time, I made a small hole in the expansion bottle cap.  It runs with no pressure in the system. That's right, at full operating temps, you can squish the hoses as if they were cool. No more blow-ups with failed hoses.
End result: the temperature now averages at one line cooler than before. Not bad. And won't kill your cat either.
Check the stuff out here:
http://www.evanscooling.com/main25.htm
I highly recommend it!
Reply #1July 31, 2004, 08:10:23 pm
QuickTD
  • 1156
« Reply #1 on: July 31, 2004, 08:10:23 pm »
They put it in cheese whiz, so its gotta be good! :D
Reply #2July 31, 2004, 09:08:20 pm
Dr. Diesel
  • 1341
« Reply #2 on: July 31, 2004, 09:08:20 pm »
so that's why this coolant goes so well on toast!   :D
Reply #3August 02, 2004, 07:33:02 am
farkman
  • 172
« Reply #3 on: August 02, 2004, 07:33:02 am »
Dr. Diesel
You wouldn't happen to have an extra two gallons of this coolant that you could sell to me, would you? :D
Peter
Reply #4August 02, 2004, 09:14:02 am
Dropout
  • 20
« Reply #4 on: August 02, 2004, 09:14:02 am »
Is it just propylene glycol or do they add something to it?
Dropout
Reply #5August 02, 2004, 10:09:17 am
Dr. Diesel
  • 1341
Koolunt
« Reply #5 on: August 02, 2004, 10:09:17 am »
I have one spare gallon, which I'd like to hold onto, and I have no idea if it's straight PG or spiked with something. Maybe try contacting them for your answers.
Reply #6August 02, 2004, 10:40:16 am
TDIMeister
  • 284
Re: Koolunt
« Reply #6 on: August 02, 2004, 10:40:16 am »
Quote from: "Dr. Diesel"
They probably add some corrosion inhibitors and stuff, but otherwise you can obtain the base propylene glycol real cheap at a food producer.  Water significantly degrades the boiling and freezing points of the stuff, and probably corrosion resistance as well.  It's important to ensure there's no water in the cooling system at all...
I've followed this company (Evans Cooling) since the late 80s when there was a write-up about it in the then VW&Porsche magazine (now European Car).  I don't have a cooling problem in my car (in fact, I have a LACK OF HEATING problem in winter :P ) but I believe it does work as advertised.
Note however, that the intent is not for this coolant to run cooler, although it can be a side effect (or benefit, depending on how you see it).  In fact, it's in order that it CAN run hotter.  P.G. has a boiling point ~100+ *F higher than E.G./water blends, so localized nucleate boiling (i.e. at a hot spot in the cylinder head) can be that much delayed -- in other words, P.G. will stay liquid (which is much more effective for heat capacity in a given volume than vapour) to a higher temperature than E.G.  If you are seeing a BIG temp drop from going to the P.G. coolant, you probably have inherent hot-spot problems that this coolant is able to fix or mask.  You might have similar results on a water/E.G.-based coolant and adding a bottle of Redline Water Wetter.
It should be noted that P.G. has a lower specific heat capacity than either water or water/E.G. blend, so the real overall capacity of the cooling system, if the coolant capacity is not increased, is actually lower.
Reply #7August 02, 2004, 11:15:31 am
VWRacer
  • 649
« Reply #7 on: August 02, 2004, 11:15:31 am »
Evans' product has been popular in circle track racing for more than 15 years. The principal byproduct from the reduction in localized nucleate boiling is that an otherwise identical engine can be run approximately 100 *F hotter, which directly translates to higher thermal efficiency...ie, more power.
I don't know that it would really help a small, lightly loaded diesel, though. Most simply aren't loaded heavily enough to need it.
Stan
C-Sports Racer
Reply #8August 02, 2004, 10:07:02 pm
cheng
  • 43
« Reply #8 on: August 02, 2004, 10:07:02 pm »
it seems to me that the greatest asset of this stuff, for highway use, is that you dont have to pressurise the system.
like the doc said, no more blown hoses spewing screaming hot water vapor on your hands and face.
but at 25.00 per gal you wouldnt want to let any leaks get away from you.
oh yea! no pressure, no leaks! :lol:
K
80 Rabbit 1.5L
82 Caddy 1.6L
84 Jetta Turbo 1.6L
85 Jetta Turbo, hydraulic
ALL DIESEL ALL THE TIME, BABY!
Reply #9August 03, 2004, 10:31:01 am
VWRacer
  • 649
« Reply #9 on: August 03, 2004, 10:31:01 am »
Well, that's a good point, K, but how many times has that happened to you? I've been driving for 35 years, and last year had my first hose slip off a radiator barb...on a car with 304,000 miles!
FWIW, I've never had one fail. I change them every couple of years.
Stan
C-Sports Racer
Reply #10August 03, 2004, 10:38:46 am
Centurion
  • 65
« Reply #10 on: August 03, 2004, 10:38:46 am »
That would be cheap for me - so far I have dropped 4 loads of green on the ground - due to hoses and over pressure.
Running with no pressure at hyway speeds and for me full loads would be better.
Remember - I carry 1000 lbs plus most of the time over hill and dale - Turbo is always whining hard.
90 Jetta TD - 589,000km, 90 Jetta TD 448, FrankenJetta ...looking for a Can
Reply #11August 04, 2004, 04:52:42 pm
cheng
  • 43
« Reply #11 on: August 04, 2004, 04:52:42 pm »
as a matter of fact I just blew one the other day on my turbo!
my PM schedule isnt what it should be. Ive been lucky to get my oil changed on a somewhat regular basis. :oops:
the only other drawback I thought of is availability.
I dont think you can find this stuff at any podunk mini-mart in a pinch.
Im still thinking about it though.
Ken
80 Rabbit 1.5L
82 Caddy 1.6L
84 Jetta Turbo 1.6L
Reply #12October 09, 2004, 07:29:40 pm
ricosuave
  • 244
Re: Koolunt
« Reply #12 on: October 09, 2004, 07:29:40 pm »
Quote from: "TDIMeister"
has anyone here tried getting some base prop-gly and running it?
Reply #13November 01, 2004, 10:23:11 am
ricosuave
  • 244
« Reply #13 on: November 01, 2004, 10:23:11 am »
anyone?
Reply #14April 19, 2008, 06:08:01 pm
« Reply #14 on: April 19, 2008, 06:08:01 pm »
Since I've been running Evans NPG+, I've been asked to update this thread. I bought it locally at a racing shop, although I've seen it for sale on the internet. It was up to $32/gallon when I got it. I also bought a gallon of prep fluid for about the same price. You need to drain all antifreeze from the engine, radiator and heater, then fill the system with prep fluid, run it and drain it. Then add straight Evans. I only bought one gallon as my engine had been sitting at all angles for months, so I knew it was completely empty, and I had a new radiator. So I just flushed out my heater cores. The Evans has a higher viscosity than EG/H2O, and less heat capacity, so it may run hotter. But since it boils at a much higher temperature, hot spots in the head are very unlikely. With a more even temp, warping is also unlikely. I first tried it as my IDI ran way too hot, getting up to 250 degrees going up mountain passes, causing me to have to pull over to allow it to cool down, and drive at reduced speed. Eventually the engine died. After adding the NPG+, it still ran hot, but I could keep driving, although I would still slow down if it was approaching 240*. This engine also died after a while, but it was due to unknown holes in the hose between the turbo and air filter, causing the ingestion of lots of dirt and dust which wore the bores and rings way down. This engine ran just as hot as the previous one, but when I took it apart, I saw no signs of head gasket leakage. I'm sure the Evans helped. I now have it in my AAZ that I turned into a TDI. It doesn't have the heat problems the AAZ had, but I will keep running it as since it has no water, it can't corrode anything. Although you can run it with a low pressure cap, I run my system open as I have an old heater which is no longer available that has a very small leak. With no pressure, it isn't a problem.
