Author Topic: Air bubbles in my clear fuel line?  (Read 2564 times)
July 22, 2007, 09:58:48 pm
Barry W
« on: July 22, 2007, 09:58:48 pm »
Hi guys I got my donor motor up and running and i'm noticing some excess smoke and there are air bubbles showing up when I rev the car. I saw someone say something about the water seperater might be the problem, can that person give some more info?
Reply #1July 23, 2007, 07:31:52 am
coke
  • 254
« Reply #1 on: July 23, 2007, 07:31:52 am »
Could be the fuel filter too.
Reply #2July 23, 2007, 08:26:15 am
mk2diesel
  • 60
« Reply #2 on: July 23, 2007, 08:26:15 am »
coud also be an air leak in the pump  .....
check the return line on the filter ( pull the pin and lift the hoses ... look and see if the filter is full , then push the fitting back down , make sure its snug then replace the pin)
Reply #3July 23, 2007, 10:29:34 pm
Cheesetoast
  • 285
« Reply #3 on: July 23, 2007, 10:29:34 pm »
on the filter there's a little plastic piece on top, replace that and the o-ring, it's cheap to do.
