Air bubbles in my clear fuel line?
Topic: Air bubbles in my clear fuel line? (Read 2552 times)
July 22, 2007, 09:58:48 pm
Barry W
July 22, 2007, 09:58:48 pm »
Hi guys I got my donor motor up and running and i'm noticing some excess smoke and there are air bubbles showing up when I rev the car. I saw someone say something about the water seperater might be the problem, can that person give some more info?
July 23, 2007, 07:31:52 am
coke
July 23, 2007, 07:31:52 am »
Could be the fuel filter too.
July 23, 2007, 08:26:15 am
mk2diesel
July 23, 2007, 08:26:15 am »
coud also be an air leak in the pump .....
check the return line on the filter ( pull the pin and lift the hoses ... look and see if the filter is full , then push the fitting back down , make sure its snug then replace the pin)
July 23, 2007, 10:29:34 pm
Cheesetoast
July 23, 2007, 10:29:34 pm »
on the filter there's a little plastic piece on top, replace that and the o-ring, it's cheap to do.
1993 Golf 1.9TD
http://members.shaw.ca/adowler/
