1.6 na turboing
Topic: 1.6 na turboing (Read 7374 times)
July 22, 2007, 08:37:11 pm
irons
Newbie
1.6 na turboing
July 22, 2007, 08:37:11 pm »
I am intrested in adding a turbo to my 1.6 na diesel.
i know its been doen before. Has any one done it? have you been happy withbthe results? a huge change or minor?
could some one please supply me with some more information and links to part resources? thank you in advance
1986 vw diesel jetta 1.6L N/A
1986 vw TD jetta 1.6L
1986 vw TD jetta 1.6L parts car, what ya need?
July 23, 2007, 09:54:29 am
bevboyy
1.6 na turboing
July 23, 2007, 09:54:29 am »
Check this:
http://vwdiesel.net/phpBB/viewtopic.php?t=9719
Then check vwvortex and search for posts by 16vjohn..
The search some more here....
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
July 24, 2007, 06:15:43 am
hamradio
1.6 na turboing
July 24, 2007, 06:15:43 am »
Oh snap! I have been linked to!
July 24, 2007, 11:29:05 am
the4ork
1.6 na turboing
July 24, 2007, 11:29:05 am »
wonder if you could substitute oil squirters for ceramic coated pistons and still be safe... pistons should stay much cooler, obviously both would be best but if you didnt have squirters.... i guess that would be the next best thing right?
July 24, 2007, 02:27:42 pm
foxracer1
Authorized Vendor
1.6 na turboing
July 24, 2007, 02:27:42 pm »
I would love to see the differance in oil temps before and after coated pistons. I think if you were still moderate with fueling ceramic coating would be a big help.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
July 24, 2007, 02:34:36 pm
bevboyy
1.6 na turboing
July 24, 2007, 02:34:36 pm »
Keeping engine oil temps are key. Installing a real oil/air cooler is best bang for the buck. Keeping the intake charge cool by use of an intercooler is also helpful.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
July 24, 2007, 02:45:59 pm
foxracer1
Authorized Vendor
1.6 na turboing
July 24, 2007, 02:45:59 pm »
I would like to eliminate the oil from getting that hot to begin with. Keeping the heat(energy) in the combustion chamber and on to the turbine if so equipped would be much more efficent. If you have to cool off the oil your wasting energy.
91 S10 305 TPI T56
July 24, 2007, 03:59:01 pm
koen GTD
Newbie
1.6 na turboing
July 24, 2007, 03:59:01 pm »
I drive now an NA turbo-ed engine, because I miss shifted my other engine, and over revved it to 8800RPM, what killed it ofcourse...
So i have put al the GTD parts on an NA solid lifter engine I had laying around.
1.25 Bar 20PSI k24 turbo
governor mod, aneriod,...
fmic
without oil scuirters.
109Hp @ 5400RPM
drive it like ***ing hell... rev it to the max always and everywhere... :roll:
still goes wel after 3months now.
only had to change head gasket. But that was already leaking when it was an NA..
also a couple of exhaust manifold gaskets and studs, because I never warm it up. I rev to 6000rpm with ice cold engine.
Don't care. Engine didnt cost a thing, except the head gasket.
Diesel Boost
July 24, 2007, 04:12:36 pm
bevboyy
1.6 na turboing
July 24, 2007, 04:12:36 pm »
Inclusief zal bemannen u bent hard op uw motor... :twisted:
Hoofd pakkingen te vervanging zijn plezier niet......
My nederlands is really rusty..haven't spoken it since I was a child...please excuse...
Oh..for all us english speaking folks..
Man you are hard on your motors :twisted:
Replacing head gaskets are not fun...
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
July 24, 2007, 04:17:15 pm
koen GTD
Newbie
1.6 na turboing
July 24, 2007, 04:17:15 pm »
LOL @ translation :wink:
hope my englisch is better than your nederlandisch :wink:
I replace head gaskets on an VW diesel with my eyes closed :wink:
Diesel Boost
July 24, 2007, 04:20:49 pm
bevboyy
1.6 na turboing
July 24, 2007, 04:20:49 pm »
it's been over 35 years since I spoke it..Uw engels is goed.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #11
July 24, 2007, 04:22:50 pm
koen GTD
Newbie
1.6 na turboing
Reply #11 on:
July 24, 2007, 04:22:50 pm »
Dank u :wink:
Diesel Boost
Reply #12
July 24, 2007, 05:17:14 pm
foxracer1
Authorized Vendor
1.6 na turboing
Reply #12 on:
July 24, 2007, 05:17:14 pm »
what did you call me?? :shock:
j/k :lol:
91 S10 305 TPI T56
Reply #13
July 25, 2007, 05:01:22 pm
irons
Newbie
1.6 na turboing
Reply #13 on:
July 25, 2007, 05:01:22 pm »
so it can take a beeting but is it a big difference? your hp makes it look like a good jump in power. well worth doing?
Reply #14
July 25, 2007, 07:34:04 pm
bevboyy
1.6 na turboing
Reply #14 on:
July 25, 2007, 07:34:04 pm »
Yes you can make good power, but if you like your engine, you won't push it too hard. If you are looking a good increase in power, keep it under 15 psi, watch your EGT, be moderate with your fueling. 80-90 hp is doable - which a substancial increase in power from 52/54 hp which you have now..
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
1.6 na turboing
