Author Topic: Idle regulator valve  (Read 8655 times)
May 13, 2007, 02:10:54 pm
mansvw
  • 85
« on: May 13, 2007, 02:10:54 pm »
does the idi engine have a idle regulator valve on it? ive got the 1.9td mk3 golf....
Mk3 Golf 1.9Td AAZ
Reply #1May 13, 2007, 08:52:41 pm
« Reply #1 on: May 13, 2007, 08:52:41 pm »
which year?
Reply #2May 14, 2007, 02:25:22 am
mansvw
  • 85
« Reply #2 on: May 14, 2007, 02:25:22 am »
its a 1996 (p registration) aaz 1.9 td mark3 golf
Mk3 Golf 1.9Td AAZ
Reply #3May 14, 2007, 01:05:05 pm
« Reply #3 on: May 14, 2007, 01:05:05 pm »
it might have some sort of a/c idle boost...
Reply #4May 14, 2007, 02:17:52 pm
mansvw
  • 85
« Reply #4 on: May 14, 2007, 02:17:52 pm »
the car don't have a/c.
the msin reason i ask is because my idle is so rough, i have to keep the rev up over 2k just to stop it from stalling
Mk3 Golf 1.9Td AAZ
Reply #5May 14, 2007, 02:25:33 pm
« Reply #5 on: May 14, 2007, 02:25:33 pm »
Does your pump have one of these:
http://www.vwdieselparts.com/forum/viewtopic.php?t=6537
We're pretty sure that's an idle booster for A/C equipped cars.
Reply #6May 15, 2007, 03:16:43 am
mansvw
  • 85
« Reply #6 on: May 15, 2007, 03:16:43 am »
my injector pump, don't have that on it mate
Mk3 Golf 1.9Td AAZ
Reply #7May 15, 2007, 03:21:29 am
mansvw
  • 85
« Reply #7 on: May 15, 2007, 03:21:29 am »
here's a picture
Mk3 Golf 1.9Td AAZ
Reply #8May 15, 2007, 08:43:02 am
« Reply #8 on: May 15, 2007, 08:43:02 am »
OK, thanks for the picture... 99.999% sure you don't have an idle regulator, unless there's some novel mystery device buried on the other side of the pump !
Based on your other posting it sounds like you're trying to fix a low/rough idle problem... could be clogged/worn injectors, could be a misbehaving injection pump, could be really poor timing or fuel system (how's the power otherwise ??)  Can you see any air bubbles in that tiny piece of clearish tubing (the elbow bend) that leads into the pump ?  Actually on second look maybe it's not clear at that point... is there a clear section somewhere ?
What to do next depends on what tools you have:  the two easy ones are (a) removing the injectors and having them tested (15mm wrench and a 27mm deep dish socket) or (b) check the timing (cam lock, dial gauge and adapter, new valve cover gasket etc)
Reply #9May 15, 2007, 06:21:04 pm
stopping
« Reply #9 on: May 15, 2007, 06:21:04 pm »
You might have a idle speed adjusting lever on the other side of the pump it is (I think) the lever above the cold start lever on the pump.
But does that explain your rough idle? I doubt it.... but you can try timing the pump with the idle speed and cold start in the home place.
Reply #10May 15, 2007, 07:23:02 pm
« Reply #10 on: May 15, 2007, 07:23:02 pm »
Quote from: "Vincent Waldon"
Isn't it 17mm? You are refering to the hard injector lines right?
Reply #11May 16, 2007, 04:07:12 pm
mansvw
  • 85
« Reply #11 on: May 16, 2007, 04:07:12 pm »
:(  yeah its a 17mm dude and a 27mm injector socket...
progress so far guys, hopethis solves the problem.... cost me a fair bit to £££$$$
these are the old set of injectors
new replacements  :)
new glow plugs, the one on the right is the old one but the replacement that i picked up on the left is the wrong shape and size :? , that's another trip to the shops tomorrow.
What do you guys think, should this solve the problems that im having? i also removed the timing belt cover and all looks fine under there, if i wanted to do a quick check to see if the belt had jumped a tooth, how would i go about doing this?
Mk3 Golf 1.9Td AAZ
Reply #12May 16, 2007, 08:55:41 pm
« Reply #12 on: May 16, 2007, 08:55:41 pm »
turn the engine to TDC and look at the end of the cam to make sure it is level with the head. I'm not sure how to check the pump on your engine though
Reply #13May 17, 2007, 06:49:00 am
« Reply #13 on: May 17, 2007, 06:49:00 am »
AAZ has a pin that goes through the sprocket, just like a 1.6
Reply #14May 17, 2007, 07:12:42 am
mansvw
  • 85
« Reply #14 on: May 17, 2007, 07:12:42 am »
jimfoo - "what does the pin indicate, and what should i be looking for? any pics?"
burn_your_money - "Ill give that a go, makes sense.. i could do that tonight"
Mk3 Golf 1.9Td AAZ
