Author Topic: Replaced injectors, damn thing wont start now!!  (Read 3672 times)
April 24, 2007, 08:28:35 pm
« on: April 24, 2007, 08:28:35 pm »
01 TDI Jetta
Replaced tips and had injectors poped, re installed and cranked this thing for a good 20 - 40min and nothing.
I'm getting some slight bubbling from #1 and #4 but that's it.
Any sugestions?
dan :!:  :!:
Reply #1April 24, 2007, 09:24:20 pm
jackbombay
  • 599
Re: Replaced injectors, damn thing wont start now!!
« Reply #1 on: April 24, 2007, 09:24:20 pm »
Quote from: "zukgod1"
01 TDI Jetta
  Sounds like you loosened the injector line at the injector to bleed air from the lines, right? Is the fuel cut solenoid getting power? #3 injector electrical connection hooked up? (although I think the car still starts with it unhooked)
Reply #2April 24, 2007, 09:37:00 pm
« Reply #2 on: April 24, 2007, 09:37:00 pm »
Quote from: jackbombay
Quote from: zukgod1
01 TDI Jetta
  Sounds like yo uloosened the injector line at the injecotr to bleed air fromt he lines, right? Is the fuel cut solenoid getting power? #3 injector electrical connection hooked up? (although I think the car still starts with it unhooked)
It just started. Some magic blue smoke leaked out of the starter but it finally started. I've never had such a hard time getting one of these started after a injector swap.
Thanks for the help though.
Dan
Reply #3April 24, 2007, 09:41:20 pm
jackbombay
  • 599
« Reply #3 on: April 24, 2007, 09:41:20 pm »
You should put the smoke back in the starter ASAP  :lol:
Reply #4April 25, 2007, 05:12:01 am
« Reply #4 on: April 25, 2007, 05:12:01 am »
Yes yes!
Ya know though, I've just never had much luck getting it back in.
I've tried the smoke in a can before but it just leaks out.
