Author Topic: Low compression - What to do?  (Read 4423 times)
October 22, 2006, 09:08:38 pm
klr650@
  • 52
« on: October 22, 2006, 09:08:38 pm »
I've got a longblock that has low compression. Any suggestions on what the potential problem could be? Unfortuantely, to keep my project moving I sent all my components to be installed on a new rebuilt engine. So I'm not sure what tests I can run any tests.
Dave
1993 Suzuki Sidekick w/ 1.9TD
Reply #1October 23, 2006, 01:14:34 pm
« Reply #1 on: October 23, 2006, 01:14:34 pm »
Do you have the injection pump still? If you have the timing belt installed I'm pretty sure you can do all the checks you need to to figure it out
Reply #2October 25, 2006, 06:12:49 am
Darkness_is_spreading
  • 288
« Reply #2 on: October 25, 2006, 06:12:49 am »
make sure you have the right size for compression test unit, lot's on ebay and  once you pull the injectors out,  you need to replace the heat shields....
disconnect the GP harness, and Fuel shut off solenoid (  hard to start when the motor is running purley of compression) and crank the motor
92 Jetta 1.6 T (Sleepin)
