Author Topic: High Egt's (newbie)  (Read 2880 times)
September 13, 2006, 01:13:32 pm
mattmey
  • 21
High Egt's (newbie)
« on: September 13, 2006, 01:13:32 pm »
Hey guy’s
The new 1.6 Td is running good but saw a few issues on the last outing with her.  The Egt’s are higher than I like.  I noticed it when I am on the power (low to mid rpm range (no tach)) and climbing hills.  Had to back out of the throttle when she hit 1200 F pre turbo.  I have an intercooler that I know will help but haven’t had time to hook it up yet.
The motor: brand new bearing andbored with oversized pistons.  Head redone with new guides, seals, and valve job.
Also I have blocked off the blow off valve, advanced the pump and turned up the pressure on the wastegate to open at 17 psi and rebuilt the turbo.  Could I have the pump too far advanced?  I advanced it .042” (1.05 mm).  I haven’t turned up the fuel screw yet either, figured that would hinder not help.
Any ideas?
Also I think I have read that I shouldn't go over 1200 deg F pre turbo correct?
Thanks,
Matt
Reply #1September 13, 2006, 01:29:43 pm
vwmike
  • Authorized Vendor
  • 1158
High Egt's (newbie)
« Reply #1 on: September 13, 2006, 01:29:43 pm »
1400+ is about the range where you should try not to let it stay too long. I think it's supposed to be over 1300 stock.
Reply #2September 13, 2006, 01:51:29 pm
mattmey
  • 21
High Egt's (newbie)
« Reply #2 on: September 13, 2006, 01:51:29 pm »
1400 Pre Turbo ?[/quote]
Reply #3September 13, 2006, 01:55:38 pm
vwmike
  • Authorized Vendor
  • 1158
High Egt's (newbie)
« Reply #3 on: September 13, 2006, 01:55:38 pm »
Yes. Temps should be cooler than that post turbo.
Reply #4September 13, 2006, 05:07:37 pm
DVST8R
  • 535
High Egt's (newbie)
« Reply #4 on: September 13, 2006, 05:07:37 pm »
If you still have stock exhaust that is a big egt problem, as well as bring the max boost to about 25psi, and hook up that intercooler. Then you will need more fuel...  :wink:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #5September 14, 2006, 09:17:10 am
mattmey
  • 21
High Egt's (newbie)
« Reply #5 on: September 14, 2006, 09:17:10 am »
Oops, should have mentioned the exhaust.  2.5" mandel bend all the way back, no muffler.
Also is 25 psi too much for stock head bolts?
Reply #6September 14, 2006, 09:27:20 am
DVST8R
  • 535
High Egt's (newbie)
« Reply #6 on: September 14, 2006, 09:27:20 am »
Are you still using the stock down pipe?
No.
Reply #7September 14, 2006, 09:30:08 am
mattmey
  • 21
High Egt's (newbie)
« Reply #7 on: September 14, 2006, 09:30:08 am »
Nope.  2.5" from turbo down to Stainless flex pipe back to 2.5"
Reply #8September 14, 2006, 05:48:21 pm
DVST8R
  • 535
High Egt's (newbie)
« Reply #8 on: September 14, 2006, 05:48:21 pm »
Bump the Psi and report back. You shouldn't have ANY egt concerns with an exhaust like that on a stock fuelled pump.
