General Information
Troubleshooting
Stripped pan bolt
Topic: Stripped pan bolt (Read 5229 times)
August 25, 2006, 11:08:14 pm
jgueld
Newbie
Stripped pan bolt
August 25, 2006, 11:08:14 pm »
Replaced the Oil Pan and found one bolt that was almost stripped and now won't seal right - oil leaking.
Question, will extra silicone help or is there a better fix (JB Weld or something)?
August 26, 2006, 03:38:27 pm
Stripped pan bolt
August 26, 2006, 03:38:27 pm »
I dont have experience with any, but try one of those thread fixers.
Remove the pan and give it a good cleaning.. especially at the point of the stripped bolt. Worth a shot!
August 28, 2006, 01:07:45 pm
saurkraut
Stripped pan bolt
August 28, 2006, 01:07:45 pm »
helicoil!
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
'86 Audi 5000 Turbo Quatro Wagon
92 Audi 100
'93 Eurovan
'82 Porsche 930
August 29, 2006, 01:35:49 pm
Stripped pan bolt
August 29, 2006, 01:35:49 pm »
tap the hole to fit a slightly larger sized bolt
November 06, 2006, 07:18:46 pm
Mike D.
User+
Stripped pan bolt
November 06, 2006, 07:18:46 pm »
Helicoil is the way to go. everything else is a bandaid. striped threads are common on alluminum parts on motorcycles and helicoils work good, last a long time.
November 06, 2006, 07:31:07 pm
andy2
Stripped pan bolt
November 06, 2006, 07:31:07 pm »
Sometimes you can get away with using a longer bolt to access the remaining good threads further into the stripped hole.Not the perfect fix but it works in some cases where thread repair is almost not an option :lol:.
November 10, 2006, 07:20:34 pm
Doug
Stripped pan bolt
November 10, 2006, 07:20:34 pm »
The pan bolts are 6X1mm I believe. You can sometimes slip a 1/4X20 tap in and get enough bite to do the job. Best of all though go buy a Recoil kit at Carquest or Princess auto to fit a proper 6X1 mm bolt to the hole. They are made in Australia and are cheaper than US made Helicoil. These kits are cheap and you will use it again sometime in the future. Besides it is a pain in the ass changing wrenches and remembering which hole has the odd sized bolt
General Information
Troubleshooting
Stripped pan bolt
