Author Topic: Stripped pan bolt  (Read 5223 times)
August 25, 2006, 11:08:14 pm
jgueld
  • 11
Stripped pan bolt
« on: August 25, 2006, 11:08:14 pm »
Replaced the Oil Pan and found one bolt that was almost stripped and now won't seal right - oil leaking.
Question, will extra silicone help or is there a better fix (JB Weld or something)?
Reply #1August 26, 2006, 03:38:27 pm
Stripped pan bolt
« Reply #1 on: August 26, 2006, 03:38:27 pm »
I dont have experience with any, but try one of those thread fixers.
Remove the pan and give it a good cleaning.. especially at the point of the stripped bolt.   Worth a shot!  :)
Reply #2August 28, 2006, 01:07:45 pm
saurkraut
  • 904
Stripped pan bolt
« Reply #2 on: August 28, 2006, 01:07:45 pm »
helicoil!
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #3August 29, 2006, 01:35:49 pm
Stripped pan bolt
« Reply #3 on: August 29, 2006, 01:35:49 pm »
tap the hole to fit a slightly larger sized bolt
Reply #4November 06, 2006, 07:18:46 pm
Mike D.
  • 23
Stripped pan bolt
« Reply #4 on: November 06, 2006, 07:18:46 pm »
Helicoil is the way to go. everything else is a bandaid. striped threads are common on alluminum parts on motorcycles and helicoils work good, last a long time.
Reply #5November 06, 2006, 07:31:07 pm
andy2
Stripped pan bolt
« Reply #5 on: November 06, 2006, 07:31:07 pm »
Sometimes you can get away with using a longer bolt to access the remaining good threads further into the stripped hole.Not the perfect fix but it works in some cases where thread repair is almost not an option :lol:.
Reply #6November 10, 2006, 07:20:34 pm
Doug
Stripped pan bolt
« Reply #6 on: November 10, 2006, 07:20:34 pm »
The pan bolts are 6X1mm I believe. You can sometimes slip a 1/4X20 tap in and get enough bite to do the job. Best of all though go buy a Recoil kit at Carquest or Princess auto to fit a proper 6X1 mm bolt to the hole. They are made in Australia and are cheaper than US made Helicoil. These kits are cheap and you will use it again sometime in the future. Besides it is a pain in the ass changing wrenches and remembering which hole has the odd sized bolt
