Author Topic: 93 td dyno results  (Read 7003 times)
May 27, 2006, 05:04:00 pm
Cheesetoast
  • 285
93 td dyno results
« on: May 27, 2006, 05:04:00 pm »
straight pipe exhaust, 2.5"
tdi intercooler
lightened flywheel
fueling turned up
1.6td boost pin
%5 biodiesel
boost controller set at 20psi
lowest one is what i was running at as a daily, very safe egt's, then we turned it up a bit, and a bit more.  Dyno run in 4th gear, videos to come later.
Reply #1May 27, 2006, 05:14:34 pm
Cheesetoast
  • 285
93 td dyno results
« Reply #1 on: May 27, 2006, 05:14:34 pm »
an interesting sidenote too, i noticed this plug was unplugged for whatever reason, it goes to the little switch that the throttle leaver triggers at wot, i have it bypassed as smog's instructions, not functioning, but still plugged in.
when i plugged this back in, the hp dropped 5 and they said i was smoking more with it in than wihtout.
Reply #2May 27, 2006, 05:32:28 pm
  • 1156
    • Malone Tuning Ltd.
93 td dyno results
« Reply #2 on: May 27, 2006, 05:32:28 pm »
Nice  :) Your modification list sounds dirt cheap.. and not many 90HP TDIs with a $400 chip remap and a $300 injector upgrade can make 140whp.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #3May 27, 2006, 09:30:42 pm
DVST8R
  • 535
93 td dyno results
« Reply #3 on: May 27, 2006, 09:30:42 pm »
It's all because of my custom cut fuel pin.... :roll:  :P
Nice pulls  8)
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #4May 27, 2006, 10:07:52 pm
zagarus
  • 619
93 td dyno results
« Reply #4 on: May 27, 2006, 10:07:52 pm »
ya mine nice dyno today, i liked the smoke  :lol:   Cant wait to get mine up there.  (i was the one asking all the questions about your car) 8)   i got some vids too, ill post'em for ya.
Reply #5May 28, 2006, 01:23:19 am
Benjamin
  • 485
93 td dyno results
« Reply #5 on: May 28, 2006, 01:23:19 am »
Gr8 power you got there!!  8)
Its time for a 1/4mile run?  :D
Greetz, Benjamin
Must make +250hp
Reply #6May 28, 2006, 01:43:32 am
Maarten
  • 339
93 td dyno results
« Reply #6 on: May 28, 2006, 01:43:32 am »
Nice figures :) What do you think the 1/4 mile will be?
If I compare that to my run I see that there is more to gain with a K24 turbo  8) My max was at the same RPM as yours, but then it ran about horizontal till the same region where yours dropped.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #7May 28, 2006, 02:22:10 am
  • 1156
93 td dyno results
« Reply #7 on: May 28, 2006, 02:22:10 am »
I'm guessing his car with current modifications is capable of 16 sec in the 1/4 mile with decent driving.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #8May 28, 2006, 12:14:19 pm
Cheesetoast
  • 285
93 td dyno results
« Reply #8 on: May 28, 2006, 12:14:19 pm »
here's the vids, all the smoke is before boost, as i floored it from 1000rpm, bogs it big time, if i knew the dyno started at liek 2000, i woulda done it from there instead.
http://www.bcvwdrivers.ca/hosted/aarondyno/run1.avi
http://www.bcvwdrivers.ca/hosted/aarondyno/run2.avi
Reply #9May 28, 2006, 12:15:46 pm
Cheesetoast
  • 285
93 td dyno results
« Reply #9 on: May 28, 2006, 12:15:46 pm »
1/4 mile run last year with the boost controller setup wrong and fueling at the lowest settings was 17.4, very good launch.  I'll be doing 1/4 mile again this year.
Quote from: Benjamin
Greetz, Benjamin
Reply #10May 28, 2006, 12:17:04 pm
Cheesetoast
  • 285
93 td dyno results
« Reply #10 on: May 28, 2006, 12:17:04 pm »
Quote from: Maarten
can you post your dyno or mail it to me? my next upgrade would be a turbo, but i dont' want too much low end loss, as this is a daily driver.
Reply #11May 28, 2006, 01:39:01 pm
Maarten
  • 339
93 td dyno results
« Reply #11 on: May 28, 2006, 01:39:01 pm »
http://www.caddy.fiberworld.nl/dyno1.jpg
running 17.5PSI boost, midly modded governor (1.6D stiffer spring, 2 washers), GTD LDA pin, 3" DP, 2.25" exhaust, big renault van IC, 2.25 plumbing, fuel turned up.
in both graphs you see the torque climbing to about 3000rpm, mine keeps level but yours starts to decline from there, I think lack of flow of the small turbo and restrictive turbine.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #12May 28, 2006, 04:31:43 pm
935racer
93 td dyno results
« Reply #12 on: May 28, 2006, 04:31:43 pm »
Quote from: DVST8R
Nice pulls  8)
Actually thats the fuel pin I cut and was running in my caddy in its 1.6td days, which than went to malone, which is now in this pump, thats a slutty fuel pin :lol:
Anyways, this dyno reading is not accurate. What the correction factor or whatever they call it? My guess is you are putting down more around the 110whp range, maybe 120, but I think even that would be overly optimistic. With a governor mod, one of my 1.9 dp's, custom cam you would be getting around 140whp.
Reply #13May 28, 2006, 04:33:45 pm
935racer
93 td dyno results
« Reply #13 on: May 28, 2006, 04:33:45 pm »
Oh and a k24 or t3 would be a really really good idea :D
Reply #14May 28, 2006, 05:01:11 pm
  • 1156
93 td dyno results
« Reply #14 on: May 28, 2006, 05:01:11 pm »
I just learned that a stock 90HP ALH TDI dynoed 106whp on the same dyno the same day... so unfortuantely the numbers are a bit exaggerated this time.
17% correction factor on a Dyno Dynamics dyno is used to emulate a Dynojet.
Using 17% correction, 106.6whp dyno = 89whp (for the stock TDI).. a lot more realistic.
In Cheesetoast's case 141.1whp dyno = 117whp. That's nothing to be disappointed about with minimal mods, it's still at least a 42whp gain over stock.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
