Author Topic: 93 td dyno results  (Read 7005 times)
Reply #15May 28, 2006, 08:08:40 pm
mkosem
  • 17
    • http://www.mattkosem.com
93 td dyno results
« Reply #15 on: May 28, 2006, 08:08:40 pm »
Quote from: Maarten
http://www.caddy.fiberworld.nl/dyno1.jpg
running 1.75PSI boost, midly modded governor (1.6D stiffer spring, 2 washers), GTD LDA pin, 3" DP, 2.25" exhaust, big renault van IC, 2.25 plumbing, fuel turned up.
in both graphs you see the torque climbing to about 3000rpm, mine keeps level but yours starts to decline from there, I think lack of flow of the small turbo and restrictive turbine.
1.75psi or 1.75 bar?
--Matt
01 Golf GL TDI - Sprint764, Mufflerectomy
Reply #16May 29, 2006, 12:15:06 am
Maarten
  • 339
93 td dyno results
« Reply #16 on: May 29, 2006, 12:15:06 am »
Quote from: malone
In Cheesetoast's case 141.1whp dyno = 117whp. That's nothing to be disappointed about with minimal mods, it's still at least a 42whp gain over stock.
I ran ~112WHP with about 10% correction = 124.8HP
Quote from: mkosem
--Matt
1.2bar / 17.5PSI, small typo ;)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #17May 29, 2006, 12:35:53 am
zagarus
  • 619
93 td dyno results
« Reply #17 on: May 29, 2006, 12:35:53 am »
the beauty of toast on cheese  :lol:
