Author Topic: AAZ Vanagon losing oil  (Read 25913 times)
Reply #60May 22, 2017, 06:57:40 am
  • 5104
Re: AAZ Vanagon losing oil
« Reply #60 on: May 22, 2017, 06:57:40 am »
also, i would try to find the fuel line clamps to help prevent them from vibrating and breaking.
I think the electronics on the pump controls the timing advance and timing, kind of like the solenoid on some injection pump timing covers.  but i am not sure.
Reply #61May 22, 2017, 08:48:45 am
RockOcean
  • 139
« Reply #61 on: May 22, 2017, 08:48:45 am »
I don't have the belt for that set up. I would also have to put on the power steering pump, and a/c compressor to get that to work.
Reply #62May 22, 2017, 05:04:42 pm
Gizmoman
  • 1301
« Reply #62 on: May 22, 2017, 05:04:42 pm »
Sounds like your real close!
Congrats on getting it in already. I find that setbacks can be good just to keep things going at a logical pace ;)
Reply #63May 22, 2017, 05:15:48 pm
RockOcean
  • 139
« Reply #63 on: May 22, 2017, 05:15:48 pm »
I ordered the factory no a/c, no power steering water pump pulley from VW today. Will be here tomorrow along with my old turbo with the correct oil feed adapter on it. Here is a picture of the insane cylinder wall wear on number 4. I don't know how it still ran so well and started up fine with that much wear? Any thoughts on what made it wear like this?
#4CylinderWear by RockOcean.com, on Flickr
Reply #64May 22, 2017, 06:19:48 pm
  • 5104
« Reply #64 on: May 22, 2017, 06:19:48 pm »
headgasket or injector?  maybe a bad oil squirter in that cylinder?
Reply #65May 22, 2017, 06:45:32 pm
« Reply #65 on: May 22, 2017, 06:45:32 pm »
What condition were the rings when you removed them?  Almost looks like metal on the top of the cylinder wall.  Heat issue?
Reply #66May 23, 2017, 04:13:44 am
« Reply #66 on: May 23, 2017, 04:13:44 am »
I'm guessing fuel wash or ingested debris.
Reply #67May 23, 2017, 06:11:20 am
  • 5104
« Reply #67 on: May 23, 2017, 06:11:20 am »
reading over the entire thread it sounds like a lot of dirt did get in the engine, and if you look the other bores are very worn out for a relatively fresh engine so that would make sense.
Reply #68May 23, 2017, 02:33:14 pm
RockOcean
  • 139
« Reply #68 on: May 23, 2017, 02:33:14 pm »
Woooohoooo started right up! Time for a 100 mile test run. Thanks everyone for all your help :~ )
Reply #69May 23, 2017, 04:49:07 pm
« Reply #69 on: May 23, 2017, 04:49:07 pm »
Nice!  I'd ditch the K&N and get a filter that doesn't pass the fine dust.
Reply #70May 23, 2017, 07:20:08 pm
Gizmoman
  • 1301
« Reply #70 on: May 23, 2017, 07:20:08 pm »
That thars melted aluminium - seen it (but a lot worse).
Reply #71May 24, 2017, 04:44:42 am
  • 5104
« Reply #71 on: May 24, 2017, 04:44:42 am »
K&N=snakeoil
Reply #72May 24, 2017, 01:06:16 pm
Gizmoman
  • 1301
« Reply #72 on: May 24, 2017, 01:06:16 pm »
Reply #73May 24, 2017, 01:13:29 pm
RockOcean
  • 139
« Reply #73 on: May 24, 2017, 01:13:29 pm »
So what cone filter company do you recommend?
Sent from my SM-G925V using Tapatalk
Reply #74May 24, 2017, 01:30:41 pm
Gizmoman
  • 1301
« Reply #74 on: May 24, 2017, 01:30:41 pm »
Not sure about cone filters specifically but Donaldson makes some good filters that are extremely suited to keep fine dust out of your new engine. There are probably quite a few others that would do the job as well.
https://www.mrostop.com/g070020-donaldson-air-cleaner-fpg-radialseal.html?gclid=CjwKEAjw3pTJBRChgZ3e7s_YhAkSJAASG9Vr7q2z1AUnBYn6_UBrkfIy7FOergLKMMocNYzl5g1SxBoCn_Pw_wcB
You may find something at your local autoparts store that could be swapped into the same housing. Take you filter in and see whats available or possibly check online.
