Author Topic: AAZ Vanagon losing oil  (Read 25850 times)
Reply #75May 27, 2017, 01:03:29 am
Re: AAZ Vanagon losing oil
« Reply #75 on: May 27, 2017, 01:03:29 am »
I don't think that pump has proper timing control. It's more like a TDI pump where the internal pressure is constant and that solenoid you highlighted in red pulses to control the timing. Keep a close eye on EGTs and MPGs. I could be wrong. That's not a North American pump so I'm not very familiar with them.
Reply #76May 28, 2017, 05:15:37 pm
RockOcean
  • 139
« Reply #76 on: May 28, 2017, 05:15:37 pm »
I made it across the country with no problems. It is nice to not have to put oil in every 200 miles :~ )
I will post photos of the pistons and rings once I get settled in a few days. Is there any chance that it was not bored straight? And that caused the extreme wear on that top half of the cylinder wall.
Reply #77May 29, 2017, 10:37:53 am
Gizmoman
  • 1301
« Reply #77 on: May 29, 2017, 10:37:53 am »
You got some real gnarly nads that's for sure - good on ya!
I suppose anything is possible but I believe when cylinders are bored, they are all quite parallel with each other unless someone moves something between bores. As I mentioned, my #4 bore looked very similar and it was due to over fueling/boosting while climbing a long grade as I had no EGT gauge and was using water temps to check heat - very bad idea. The silver stuff at the top of the bore is aluminum from your piston. My engine ran after that, and not too bad - just made enough unburnt fuel smoke to cloud a 4-lane freeway.
