Author Topic: broke compressor mount ear  (Read 3993 times)
October 12, 2014, 08:33:35 am
ropadopa
  • 58
« on: October 12, 2014, 08:33:35 am »
Well my trusty eco diesel just threw me a good one. After replacing my trans mount i was so happy hot dogging along and my ac belt started squealing. Took a look and the ear of my ac compressor and its broke off. i thought i finally had a good grip on keeping that mouse trap of acessossories and belts working but Dang this really took the wind out of my sails.
I while back i tried to follow along with what it takes to convert this to a serpentine belts but it just got to confusing using ac and power steering. Besides me welding another ear on this compressor there has to be a better way.
Please any input what so ever would be great.
1992 ecodiesel
Reply #1October 12, 2014, 10:12:18 am
thegimpster
  • 243
    • VDubShirts.com Awesome VW themed shirts with attitude
Re: broke compressor mount ear
« Reply #1 on: October 12, 2014, 10:12:18 am »
Does the ac work? I've probably got another compressor laying around. If not and you could delete it change the belt setup. I've done a deep swap but its been a while. I think I used a tensioner mount off of an aba I cut down and vr6 water pump pulley. I'll have to go back and see what I did.
Check out www.vdubshirts.com for cool VW themed shirts with attitude.
Reply #2October 12, 2014, 11:59:48 am
ropadopa
  • 58
« Reply #2 on: October 12, 2014, 11:59:48 am »
ac is a must, best thing about the car........lol   lmk about that compressor
1992 ecodiesel
Reply #3October 16, 2014, 06:10:03 am
ropadopa
  • 58
« Reply #3 on: October 16, 2014, 06:10:03 am »
any more suggestions?
1992 ecodiesel
Reply #4October 16, 2014, 07:51:43 am
samuraij
  • 26
« Reply #4 on: October 16, 2014, 07:51:43 am »
Tig weld the ear, or replace the compressor... That's about all you can do!
88 Suzuki Samurai - 86 VW 1.6D N/A
Reply #5October 16, 2014, 01:20:37 pm
ropadopa
  • 58
« Reply #5 on: October 16, 2014, 01:20:37 pm »
thanks, dug into this today. I remember a while back replacing that bolt because it was snapped off seems that some one had it rigged before . I did replace it with a different bolt not a vw one and thought i had it squared away but it fudged it all up this time.  The dealer says he has a bolt in stock. Im going to pick it up. And see how it fits . something just dosent seem right.
so, my big question of the day is  after looking at this should that bolt go all the way through the backside and have a nut to secure it on the front side or should the bracket be threaded to accept the bolt.
thanks again in advance
1992 ecodiesel
Reply #6October 16, 2014, 03:22:14 pm
ropadopa
  • 58
« Reply #6 on: October 16, 2014, 03:22:14 pm »
alright i may have solved the mystery........
the bracket and someones makeshift bushing.
A while back there was a snapped of through bolt in this location and , i did not give it to much thought and put another incorrect through bolt in it.
while taking it apart i found this awesome part which i believe is supposed to be a threaded bushing
my cool bolt that was in there for the last year which was a rig on top of a rig.
so just to verify if i have this right after looking at the drawings at the dealer. I ordered two threaded bolts same size.  the blue side gets a threaded bushing and bolt and i believe that the red side should have been threaded to accept my other bolt but has been drilled out buy the through bolt genius prior to me. I think the red side should be threaded and not drill all the way through.
can anyone verify this or correct me. Thanks again
« Last Edit: October 16, 2014, 03:36:46 pm by ropadopa »
1992 ecodiesel
Reply #7October 17, 2014, 12:21:40 am
« Reply #7 on: October 17, 2014, 12:21:40 am »
I'll go look tomorrow when its daylight.
Wouldn't the easiest thing to do just be to get another compressor? I don't think there's a difference between them on the 8v gas and diesel motors, so go get an mk2 compressor from the junkyard. You would have to deal with the refrigerant and recharging it though.
Reply #8October 17, 2014, 06:53:30 am
ropadopa
  • 58
« Reply #8 on: October 17, 2014, 06:53:30 am »
I dont mind welding or charging/ re charging the system i just want to bolt it up correct with the correct hardware so it does not happen again.
this is the best generic drawing im working with.
Its the lower picture.
reference 33/26 i have covered colored in green......how does the front of the compressor mount in blue. I believe it was threaded in the bracket but cant confirm. I will probably put a threaded insert in there but im trying to verify how it is supposed to go
thanks again.
1992 ecodiesel
Reply #9October 17, 2014, 09:07:00 am
EcoTX
  • 113
« Reply #9 on: October 17, 2014, 09:07:00 am »
I have all the MK2 AC stuff I took off my 92 ECOdiesel in boxes exactly how it came off the car.
Every nut, bolt, and bracket...
Problem is, I won't be able to get you a picture of how it all goes until later tonight, possibly tomorrow morning.
Reply #10October 17, 2014, 04:53:13 pm
ropadopa
  • 58
« Reply #10 on: October 17, 2014, 04:53:13 pm »
awsome. LMK
1992 ecodiesel
Reply #11October 17, 2014, 05:02:06 pm
ropadopa
  • 58
« Reply #11 on: October 17, 2014, 05:02:06 pm »
MY buddy gave it  a new set of ears
1992 ecodiesel
Reply #12October 17, 2014, 06:11:51 pm
samuraij
  • 26
« Reply #12 on: October 17, 2014, 06:11:51 pm »
Lookin' good!
Reply #13October 20, 2014, 06:58:12 am
92EcoDiesel Jetta
« Reply #13 on: October 20, 2014, 06:58:12 am »
By welding? You could have re-clocked it to get a new ear. The only change is the orientation of the clutch connector.
Reply #14October 20, 2014, 06:42:25 pm
ropadopa
  • 58
« Reply #14 on: October 20, 2014, 06:42:25 pm »
thought of that but had some thoughts about oiling issues.  Got her mounted back up still. had to order a new alt belt. should be back in action tomorrow.
1992 ecodiesel
