Author Topic: Compression Test Injector Adapter for 1.6 Mk2 Engine???  (Read 17374 times)
May 20, 2014, 08:15:58 pm
ftm1776
  • 149
« on: May 20, 2014, 08:15:58 pm »
Does someone make an Injector Type Adapter for compression testing the VW 1.6 non-turbo diesel engine?
My car is a 1991 MK2 with the 1.6 engine. I'm the original owner.
Otherwise, the glow plug type adapter would require the removal of the injection pump.....I think.
What size is the injector thread on this engine???
Comments please.
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1May 20, 2014, 11:03:45 pm
Re: Compression Test Injector Adapter for 1.6 Mk2 Engine???
« Reply #1 on: May 20, 2014, 11:03:45 pm »
Yes - the cheap Harbor Freight compression tester has a fitting that will work with these engines via the injector hole.  I don't know the actual size but it's the same as Mercedes and the 6.2/6.5L GM diesels.
Reply #2May 21, 2014, 11:21:15 am
ftm1776
  • 149
« Reply #2 on: May 21, 2014, 11:21:15 am »
OK. I see the tester....#93644 is the one I'm looking at.....about $30.
I noticed that the one shown on the HF webpage has "12 pieces" and the one shown on the attached PDF of the 93644 Owner Manual has about 19 pieces. I'll have to check this out at Harbor Freight. Model specs seem to have changed. Just wondering if it still fits my mechanical diesel????
293,000 miles
Reply #3May 21, 2014, 12:58:15 pm
« Reply #3 on: May 21, 2014, 12:58:15 pm »
Most likely.  The GMC 6.2/6.5L engines are so insanely common in North America it'd be suicide not to support them.
Reply #4May 21, 2014, 05:23:58 pm
sgnimj96
  • 185
« Reply #4 on: May 21, 2014, 05:23:58 pm »
       The injector adapter in the center of the HF pic is the one for vw/mercedes idi.    Hansautoparts sells the exact same gauge and adaptor.
 Pressure relief valve on the gauge barely works on mine , had to press it a bunch of times- may have got a bad one... but it got the job done
81 Scirocco 1.6D (conversion)    86 Gofl 1.6D      2003 Golf Tdi   1985 300TD
Reply #5May 21, 2014, 06:46:21 pm
Mark(The Miser)UK
  • 1557
« Reply #5 on: May 21, 2014, 06:46:21 pm »
That's the wrong adaptor, or if deemed correct, will give bad results... :o
Mark-The-Miser-UK
Reply #6May 21, 2014, 07:07:45 pm
sgnimj96
  • 185
« Reply #6 on: May 21, 2014, 07:07:45 pm »
[/quote]
   really?   I bought the HF kit and used that in my 1.6 na ,  but it's an '82 CR engine
  The picture is from http://www.hansautoparts.com/16CompressionFitting.aspx
« Last Edit: May 21, 2014, 07:13:08 pm by sgnimj96 »
Reply #7May 21, 2014, 07:21:40 pm
« Reply #7 on: May 21, 2014, 07:21:40 pm »
That's the correct one, but shown above without proper pieces...
pic below shows req'd sleeve and washer
Reply #8May 21, 2014, 07:42:19 pm
sgnimj96
  • 185
« Reply #8 on: May 21, 2014, 07:42:19 pm »
       Wow,  didn't know I needed the extra stuff.     I guess it sealed with just the threads,  hope I didn't scratch up anything in the prechamber.   HF tester doesn't really have instructions.     Thanks!
Reply #9May 21, 2014, 09:18:18 pm
« Reply #9 on: May 21, 2014, 09:18:18 pm »
HF adapter does need collar around the part that actually threads into the engine.  In addition to that collar I put the copper washer betwee the collar and the adapter body.  So I have the heatshield to the collar and then the washer and then the adapter.  HF kit I have has a bunch of ways you can get the flow from the adapter to the quick connect.  I like to keep the compression from having to build in the hose so I try to keep the part with the valve in it as close to the adapter as possible.  Like in the picture.  But there are 90 degree take offs and longer parts if you need em.  My Kit is the 93644 one, plenty of pieces in the red box.  The compression release works fine so perhaps yours needs more use or a bit of silicone spray.
Not using the collar probably only cut a few lbs off the reading on the gauge.  Without the volume taken up by the metal the compressed air would have filled that volume instead.  But I doubt you would see it.
I like that kit and if it is off a few lbs in measurement so what.  You are measuring all the different cylinders with the same equipment and comparing the values to one another any hoo.
Just my contribution to the cause or confusion.
Reply #10May 22, 2014, 02:31:05 am
Mark(The Miser)UK
  • 1557
« Reply #10 on: May 22, 2014, 02:31:05 am »
Ah the universal adaptor  pieces were not on display, to make it universal  ;D.
At a guess I'd say that  coller if missing would account for upwards of  1 cc.
As it's below the one way valve, it would fill up and discharge as part of the engine chamber every stroke. Further guessing, I'd say that that was approaching +15% of the compression chamber, or nearing 75psi on a good day...
Not crucial if you are just comparing cylinders, but might wrongly influence someone to embark on a $2000 rebuild if they believed the score.
Interestingly I use a standard injector bottom with nozzle holder and needle but leave out the needle thrust plate, and pack adaptor gaps with lead:o
Mark-The-Miser-UK
Reply #11May 22, 2014, 06:31:00 am
92EcoDiesel Jetta
« Reply #11 on: May 22, 2014, 06:31:00 am »
Interestingly I use a standard injector bottom with nozzle holder and needle but leave out the needle thrust plate, and pack adaptor gaps with lead:o[/color]
Where is your Schraeder valve and how did you install it? What gaps were packed with lead? I was thinking of using an old injector body/nozzle to make a compression adapter but have not actually started on it yet.
Btw, if you look into the tip of the HF injector adapter, it has a cavity leading up to the Schraeder valve. That cavity's volume is much greater than the volume of the adapter ring/copper washer.
Reply #12May 22, 2014, 08:28:06 am
8v-of-fury!
« Reply #12 on: May 22, 2014, 08:28:06 am »
Go to prothe, buy his guage and adapter for like $20. Done deal.
I've had mine since 2008, works perfectly, and tests out against snap-on units too. A machined piece of metal, a hose and a gauge are not things that can be screwed up anymore... no matter what country they were manufactured in.
Reply #13May 22, 2014, 09:07:42 am
92EcoDiesel Jetta
« Reply #13 on: May 22, 2014, 09:07:42 am »
Is the Prothe adapter a solid hunk of steel with the Schrader at the tip? If so I am buying one.
Reply #14May 22, 2014, 09:47:37 am
« Reply #14 on: May 22, 2014, 09:47:37 am »
I don't think a schrader is up to the task... 500psi?  The HF fitting is a high pressure coupler that connects to the hose with a locking collar.
